8.5:1 and 9.0:1 rings?????
Old Aug 26, 2003 | 07:28 PM
Dyno Queen's Avatar
Default 8.5:1 and 9.0:1 rings?????
Is there a difference in these 2 compression ratios in ring size on standard bore???
reason im asking is because i need to order rings and im not sure if my pistons are shelf 9 to 1's or if they are custom 8.5:1's so if there is not a difference in the rings i guess it does not matter so i just need to know, thanks
mike
Old Aug 26, 2003 | 07:55 PM
boostaholic's Avatar
Default Re: 8.5:1 and 9.0:1 rings????? (turbo gsr)
you're compression doesn't affect which rings you get, just make sure the rings are for the same bore size as your pistons.
Old Aug 26, 2003 | 08:17 PM
Dyno Queen's Avatar
Default Re: 8.5:1 and 9.0:1 rings????? (boostaholic)
Thanks man
JJDub
Engine Machining & Assembly
May 31, 2017 07:30 AM
thumper64
45
Dec 6, 2016 03:43 PM
NegativeXero
Nov 10, 2007 03:57 PM
siis2fast
Jun 7, 2005 03:52 AM
LSVtechnologytur...
Feb 6, 2005 09:07 AM
