Swapping in a 92 B18A in my 92 CX a few ?'s
Ok I am swapping in a 92 B18A in my 92 CX and I will be getting the Hydro to Cable conversion. My few questions are..
What axles to use?
What shift linkage to use?
What mounts to use?
And the 92 B18A ecu and harness will work correct? obd1 right?
Thanks for any help.
_Brandon_
What axles to use?
What mounts to use?
_Brandon_
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueHatch00 »</TD></TR><TR><TD CLASS="quote">You will need a hydro tranny, then just use 94-up ls axles, shift linkage, ecu, and stock integra mounts (94-95 integra mounts)</TD></TR></TABLE>
94-00 mounts off any integra as long as its not automatic.
94-00 int. shaft w/axles
you might need new ecu coz it might not plug in.
you might need to use your stock harness just modify it
well I will be using a cable tranny with the Hasports conversion. So will I use the 90-93 axles?
also the mounts I would think that the 94-95's would work but was not sure since maybe the mount on the T belt side on the older block was different?
My wiring harness if for a single wire o2. Isnt the motor, (ecu) going to be looking for a 4 wire? That is why I was thinking use the stock LS harness.
4gencivicef9
Jan 22, 2007 05:55 PM
92CxHatchback
Sep 8, 2003 07:01 AM
