strange clunking/popping from front suspension
Old Aug 26, 2003 | 04:44 PM
brbHPR's Avatar
Default strange clunking/popping from front suspension
i have an 89 civic and whenever i am braking or hit a hard bump, the front drivers suspension makes a clunking/popping noise. there is alot of play in the steering, and it's also very stiff turning-wise. the wheel also seems to have a bit more camber on that side.
any ideas on what it could be?
Old Aug 26, 2003 | 06:11 PM
DXDOHCVTEC's Avatar
did you change the suspension on the car?
if you did it sounds like somthing didnt get put back on
the bushing, spacer, or nut missing on top of the strut tower would be a start
Old Aug 26, 2003 | 06:14 PM
Ef Whore's Avatar
Default Re: (DXDOHCVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DXDOHCVTEC &raquo;</TD></TR><TR><TD CLASS="quote">did you change the suspension on the car?
the bushing, spacer, or nut missing on top of the strut tower would be a start</TD></TR></TABLE>
I doubt that.......Most likely it is a blown shock, or worn bushing/balljoints. My hatch made all sorts of noises until I finally replaced all the wear components.
Old Aug 26, 2003 | 07:41 PM
rasta420's Avatar
Default Re: strange clunking/popping from front suspension (brbHPR)
your drivers side radius rod could be loose or damaged...check that first, then the suspension
Old Aug 26, 2003 | 08:44 PM
brbHPR's Avatar
Default Re: strange clunking/popping from front suspension (rasta420)
oh, when i pushed down on the car, it makes a clunking sound.
if that helps any
hispanic panic
Sep 30, 2011 01:13 PM
99tegjawn
Suspension & Brakes
Apr 30, 2011 08:31 AM
GriFFIthS
Honda Civic (2001 - 2005)
May 20, 2008 05:56 AM
SiR99
Jul 30, 2006 01:39 PM
