Power Antenna Problems
the power antenna wire is obviosly connected to the parking lite wire > the parking light wire in that car is red with a black stripe >> there is also a dimmer wire in the harness > isolate the 2 parking lite wires and cap them off >> what is left is the power antenna >> check it with a fuse by tapping it to your 12 volts >> if the antenna goes up then connect it to the blue antenna output on the head unit.
geminis2k
Jan 30, 2004 09:10 AM
