HCP mount kit, eg, h22, whats the deal?
Ok, i did a search. Here is my question. I just received my hcp h22 mount kit for the eg. One question i have is they say remove the studs from the h series tranny and replace them with 14mm bolts. Ok, how long 14 mm bolt? what thread pitch?
And anyone have pics of what im asking about?
Thanks.
Thanks.
just any 14mm bolts for it. make sure the bolts are threaded all the way and i just looked at the original h22 studs and alittle just little bit longer 14mm bolts then the h22 studs. so you can put the mount in and bolt it on.
I just double-nutted the studs that came in the tranny and replaced them with 3 studs that I pulled from the a/c in the block (only comes with 2 studs though).
I can't think of the pitch off hte top of my head. Probably 1.25.
