ACCORD COUPE 2001 ENGINE MOUNT
Sorry about that. I dod get it from Majestic. Thanks. They were talking about a tube that connects to the mount. Is that a pressure tube to keep the boot inflated? Is there a possiblility of a failure to the relay that energizes the pressure tube?
I changed my front engine mount this weekend. It wasn't much of a job. Little crawling under the car and some extensions and I was fine. The boot was cracked as I suspected. I changed it and there is still a vibration in the car, mostly when I'm stopped and in gear. Also, when I start the car, when it's still cold and I'm not in gear it gives off some vibration. Is there any other possible common trouble spot? I had the car in an accident when it was pushed under a bus with the front portion of the engine.
Do you guys have any suggestions?
shrekfiona
Mar 11, 2013 02:37 AM
weakGOODJunKieS.com
Jul 25, 2002 11:53 PM
