light weight flywheels????????????????????????????????help
Old Aug 26, 2003 | 07:25 AM
mattyg1405's Avatar
Default light weight flywheels????????????????????????????????help
i just got my sir2 swap delivered and i need some advice on the fly wheel..... act 8lb flywheel? good? bad? i am running all motor and i need some help i am using an exedy racing clutch
Old Aug 26, 2003 | 07:31 AM
advanracing62's Avatar
Default Re: light weight flywheels????????????????????????????????help (mattyg1405)
I've had my JUN ultralight for about 2 years now... not a single issue with it. I love the fast revs it gives, and the minimal power loss. I think it weighs about 9lbs, so 8lbs would be OK... don't think I'd go any lighter than that.
edit- minimal power loss= poor phrasing on my part. I mean that it takes no power from the motor. No parisitic drain, or minimal parasitic drain from rotating assembly. That is to say that is has less parasitic drain than a normal "stock" fly. SORRY for the confusion.... it made sense to me when I posted it.....
Modified by advanracing62 at 4:14 PM 8/26/2003
Old Aug 26, 2003 | 07:57 AM
mattyg1405's Avatar
so i will lose a little power? i was hoping to gain lol...........
Old Aug 26, 2003 | 08:00 AM
yeer's Avatar
Default Re: (mattyg1405)
im running the act prolite and act hdss clutch
love them both.
Old Aug 26, 2003 | 08:56 AM
owen_the_soyboy's Avatar
Default Re: (yeer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeer &raquo;</TD></TR><TR><TD CLASS="quote">
love them both.</TD></TR></TABLE> me too, almost 6 months on this setup, will never go back! act 8.8# is the way to go. I even lightened my crankpulley by 3 lbs...
Old Aug 26, 2003 | 10:10 AM
blackeg's Avatar
Default Re: (owen_the_soyboy)
what about the streetlite?? it weighs a few pounds more than the prolite..would it be noticeable over stock flywheel.. act
Old Aug 26, 2003 | 11:25 AM
roadawg's Avatar
Default Re: light weight flywheels????????????????????????????????help (advanracing62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advanracing62 &raquo;</TD></TR><TR><TD CLASS="quote">I've had my JUN ultralight for about 2 years now... not a single issue with it. I love the fast revs it gives, and the minimal power loss. I think it weighs about 9lbs, so 8lbs would be OK... don't think I'd go any lighter than that.</TD></TR></TABLE>
You will not lose power with a lightened flywheel, what you will lose is inertia, AKA, momentum when shifting. I love how i can practically stop just downshifting
I have a 8.8 lb ACT flywheel with my b16 and i love how fast it accelerates and deccelerates.
Old Aug 26, 2003 | 12:08 PM
NSX Bob's Avatar
New User
Default Re: light weight flywheels????????????????????????????????help (SiRWanabe)
IMO get a Fidanza.
Old Aug 26, 2003 | 04:19 PM
Rocket's Avatar
Default Re: light weight flywheels????????????????????????????????help (Type R Bob)
Also upgrade your valve springs when going with a lighter flywheel. The more responsive your motor is the more valve spring you need.
Old Aug 26, 2003 | 05:22 PM
Charlie Moua's Avatar
Default Re: light weight flywheels????????????????????????????????help (Rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">Also upgrade your valve springs when going with a lighter flywheel. The more responsive your motor is the more valve spring you need.</TD></TR></TABLE>
thats right Rocket educate these guys on what you posted on that other thread.
Old Aug 26, 2003 | 05:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRWanabe &raquo;</TD></TR><TR><TD CLASS="quote">
I have a 8.8 lb ACT flywheel with my b16 and i love how fast it accelerates and deccelerates.</TD></TR></TABLE>
thats one of the worst things you can do to your motor we have a great system on our cars called brakes... use them rather then downshifting... WAY tooo much shock to the motor.
Old Aug 27, 2003 | 07:49 AM
1bad-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type R Bob &raquo;</TD></TR><TR><TD CLASS="quote">IMO get a Fidanza.</TD></TR></TABLE>
That's what I have and I freakin love the damn thing.
Old Aug 27, 2003 | 09:50 AM
ce's Avatar
ce
Huh ?? wtf
Old Aug 28, 2003 | 01:55 PM
roadawg's Avatar
Default Re: light weight flywheels????????????????????????????????help (Charlie Moua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">
thats one of the worst things you can do to your motor we have a great system on our cars called brakes... use them rather then downshifting... WAY tooo much shock to the motor. </TD></TR></TABLE>
I know how to drive my car. I don't downshift into 3rd going 60, I do however downshift the gears to slow down. Way too much shock to the motor? WTF
Old Aug 28, 2003 | 05:43 PM
b18crx's Avatar
I second the motion---all in favor say "I".
Old Aug 28, 2003 | 05:45 PM
b18crx's Avatar
question about this comment,
would the jdm itr(98) need an upgrade in valve springs when going with ligther flywheel. Does any engine?
Old Aug 28, 2003 | 09:16 PM
rodimus's Avatar
Default Re: light weight flywheels????????????????????????????????help (b18crx)
upgraded valvesprings could only help..
i'm sure itr valvesprings would be coo for awhile..
just depends what else u have done to the motor..
Old Aug 31, 2003 | 06:47 PM
civicsitek GanGsTa's Avatar
Default Re: light weight flywheels????????????????????????????????help (ce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ce &raquo;</TD></TR><TR><TD CLASS="quote">
Huh ?? wtf </TD></TR></TABLE>
Rebound time(valve spring) decreases as rate of acceleration increases. So even if you have a stock rev limit, stock valve springs may not be up to the task.
Old Aug 31, 2003 | 07:04 PM
turbociv's Avatar
I am running exedy flywheel and exedy clutch. I love them both. And I am running skunk 2 dual valve springs.
Old Sep 1, 2003 | 01:16 PM
ArinX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18crx &raquo;</TD></TR><TR><TD CLASS="quote">I second the motion---all in favor say "I".
I
Old Sep 3, 2003 | 10:46 PM
MisterB's Avatar
Default Re: light weight flywheels????????????????????????????????help (ArinX)
im running clutchmasters 7.5lbs almost same as fidanza and its been great except...
i know it is arguable but i recomend loctite or threadlock of some sort on the flywheel bolts. mine backed out completely. luckily it only ruined my clutch.
Old Sep 4, 2003 | 06:38 AM
justBLZE's Avatar
Chopper 2 Hopper
I was wondering what everyone thinks about the Exedy Flywheel.
+/- 9lbs + Exedy Racing Organic clutch going on B16a2 with boltons.
Another thing...why would I need to upgrade the valvesprings when going with a lighter flywheel?
Old Sep 4, 2003 | 07:50 AM
TeckniX's Avatar
So I guess that's why Formula 1 racers, rally racers and all others always go into neutral when they start slowing down... they simply only use their brakes! i was wondering also .. yeah I'm being sarcastic.
So quick question when you slow down for a turn you put yourself out of gear and apply the brakes? so basically your wheels are free to run however they want? I'd hate to be behind you in fast corners...
There is a difference between downshifting stupid, and downshifting catching your rpms as you slow down, using the engine brake as you apply your brakes to slow your car down even more and quicker.~my 2cents that will get flamed here in a sec...
Old Sep 4, 2003 | 08:50 AM
you guys still bickering?
get the lightest possible flywheel and tune your motor.
drive in love with your car.
Old Sep 4, 2003 | 08:58 AM
JeffNA's Avatar
Default Re: light weight flywheels????????????????????????????????help (owen_the_soyboy)
Lighter flywheel=Less Rotational Mass
I got the ACT and love it. The ACT is also Chromoly
