Brake fluid low.. what to use to re-fill?
Old Aug 26, 2003 | 07:21 AM
drjondurst's Avatar
Default Brake fluid low.. what to use to re-fill?
My brake fluid is low (has been since I bought the car a year and a half ago) and recently my e-brake light started randomly staying on and stuff.. especially during acceleration. I searched and come to the conclusion I need more brake fluid.. but like I said have no idea what type is in it right now. Does it matter what type I put in? Can I just buy a bottle of DOT3 or whatever and pour it in or is this process going to involve bleeding and stuff.
Old Aug 26, 2003 | 07:25 AM
HT Chaplain's Avatar
Loved
Default Re: Brake fluid low.. what to use to re-fill? (drjondurst)
since you never bleed your brakes since you owned it and dont know what the previous owner did i would just bleed the brakes and put some dot 3or 4 in there.
Old Aug 26, 2003 | 07:29 AM
drjondurst's Avatar
damnit haha, I was hoping someone wouldnt suggest that. Maybe its time for me to just do it.. I've always been kinda hesitant to touch the brakes just because of what I could possibly **** up.
I'll search in a second.. but can u give me a hint on the difference between the different DOT types of fluid?
Old Aug 26, 2003 | 07:33 AM
Steve90HB's Avatar
Default Re: (drjondurst)
you shouldn't be losing brake fluid, you better check up on it for leaks
here's a good website for brake fluid info http://www.vtr.org/maintain/brake-fluids.html
Old Aug 26, 2003 | 07:34 AM
gocivicgo's Avatar
Theres no point in mixing DOT 3 and 4, in fact im nto even sure if you can, read the bottle. ITs worth the while to rent or make a flush system, clean the brake sysytem right out, and just go to DOT 4.
Old Aug 26, 2003 | 07:43 AM
drjondurst's Avatar
Default Re: (Steve90HB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steve90HB &raquo;</TD></TR><TR><TD CLASS="quote">you shouldn't be losing brake fluid, you better check up on it for leaks
here's a good website for brake fluid info http://www.vtr.org/maintain/brake-fluids.html </TD></TR></TABLE>
Does anyone know if our cars have natural rubber seals as referred to in that site?
whats a Triumph?
Old Aug 26, 2003 | 08:15 AM
FourthGenHatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drjondurst &raquo;</TD></TR><TR><TD CLASS="quote">whats a Triumph?</TD></TR></TABLE>
Triumphs are small British Roadsters.
I believe you can mix Dot 3 and 4 but not 5 because 5 is silicone based.
I don't believe Hondas have any rubber seals for the lines, I think its just a concave double flared pipe with a fitting that screws right into threaded hole with a convex shaped pipe inside it. So any leaks would come from a loose connection or broke rubber hose.
Bleeding brakes is not hard, I have a how-to for it...
http://www.fourthgenhatch.com/brakebleeding.html
Old Aug 26, 2003 | 08:28 AM
EL Vap133's Avatar
If not get some speed bleeders and whoala!
Old Aug 26, 2003 | 08:31 AM
drjondurst's Avatar
Thanks for the howto, fourthgenhatch.. Im gonna work off that.
Old Aug 26, 2003 | 10:13 AM
Shawn C's Avatar
In The Garage
flush the whole system with valvoline synthetic DOT 3/4. it's awesome stuff, and stays clear forever, as it holds up to heat much better.
Old Aug 26, 2003 | 10:19 AM
Vinceg99's Avatar
Default Re: (22lbGS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 22lbGS-R &raquo;</TD></TR><TR><TD CLASS="quote">flush the whole system with valvoline synthetic DOT 3/4. it's awesome stuff, and stays clear forever, as it holds up to heat much better.</TD></TR></TABLE>
This is what I just did when I had to change my M/C.
*EDIT* But sicne you never really did get an answer for your question just use DOT 3 to fill it back up with. Of course check for a leak and such but its better for it to be full than to be running low even if you do have a leak keep it full if your still driving it.
DC4R27
Dec 2, 2009 10:03 AM
kommon_sense
Jan 4, 2005 11:46 AM
SilverDc2
Jun 6, 2004 08:54 PM
turbotypeR@SPEC
Dec 11, 2002 03:42 PM
JSIR
Apr 27, 2002 10:27 PM
