A/C not blowing any air?? help please
Old Aug 26, 2003 | 05:55 AM
NoNOSgsr!'s Avatar
Default A/C not blowing any air?? help please
no air is coming out of my vents-
i can hear my compressor but no air is coming out
not even hot air? i checked all fuses and all are good
please help !!
Old Aug 26, 2003 | 08:52 AM
JimBlake's Avatar
Default Re: A/C not blowing any air?? help please (NoNOSgsr!)
If your compressor is working then I guess if you drive fast enough the air flow from your speed would be cold. Right?
Then it's the ventilation fan. Fuse OK (check again...) Wires unplugged from the back of the fan switch? Does it work at the highest speed? There's a speed-control resistor pack somewhere that controls all but the fastest speed. After all that, you might have to dismantle your dashboard to check if the fan motor itself is shot.
Old Aug 26, 2003 | 11:33 AM
EsQueue's Avatar
check your relays before you take anything apart.
Old Aug 26, 2003 | 03:10 PM
NonAutoX's Avatar
Default Re: (SeaQuake)
If the compressor is not working, what does that mean?
Also, how do you check to see if its working or not?
Thanks
Old Aug 26, 2003 | 05:17 PM
NoNOSgsr!'s Avatar
Default Re: A/C not blowing any air?? help please (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">If your compressor is working then I guess if you drive fast enough the air flow from your speed would be cold. Right?
thanks i'll go ahead and find time to take things apart....anyone know a easy and safe way to pop the control unit out of the dash.
again thanks for the replies.
Old Aug 27, 2003 | 03:32 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NoNOSgsr! &raquo;</TD></TR><TR><TD CLASS="quote">...anyone know a easy and safe way to pop the control unit out of the dash.</TD></TR></TABLE>What kind of car? A lot of that stuff is easy to reach in my car by taking out the glovebox.
Old Aug 27, 2003 | 03:34 AM
JimBlake's Avatar
Default Re: (NonAutoX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonAutoX &raquo;</TD></TR><TR><TD CLASS="quote">If the compressor is not working, what does that mean?
Thanks</TD></TR></TABLE>If the compressor isn't working, then there's a bunch of different things to check. Relays, low-pressure switch, wiring to the clutch? There's lots of threads about AC not working.
You can watch the compressor clutch engaging & disengaging as the AC cycles.
twentyhurtz
Apr 8, 2006 08:51 AM
SPOT..
Mar 23, 2006 02:30 PM
JDM_SOHC
14
Aug 15, 2005 09:04 AM
Tsl13505
Jun 25, 2004 10:24 PM
Milano4
Jun 9, 2004 12:15 PM
