Turn signal lever on 5th gen
hey, search nothing did for me, so i ask...
has anyone had problems with it, not going back to original position after turning left or right?
The lever stays on one setting and it doesn't go back to the neutral position...weird, i would assume it is a switch or something...?????
Let me know.
Thanks.
Let me know.
Thanks.
Make sure that its not hitting the plastic cover for the ignition collum. Other than that usually it works or it dosen't . take it out and see if you can see something wrong with it and repair as nessary, otherwise a new/used one is in order.
Hey - I replied to your question from a couple days ago over on the classified forum -
https://honda-tech.com/zerothread?id=596558
versatyle
May 26, 2004 06:47 AM
