Largest Bore manageable By Stock ITR Manifold?
Old Aug 25, 2003 | 07:19 PM
Ruby Civic's Avatar
Default Largest Bore manageable By Stock ITR Manifold?
I have a b16 mani, and tough to go much above 64 mm. - what about polishing out an oem itr manifold - will it go to 70mm or water passage interference probs??
Old Aug 26, 2003 | 04:10 AM
Ruby Civic's Avatar
Default Re: Largest Bore manageable By Stock ITR Manifold? (zyg)
plenty, cams & compression, head, etc. the b16a mani is good for low torque but need more topend
Old Aug 26, 2003 | 05:07 AM
Spoond TEG's Avatar
Default Re: Largest Bore manageable By Stock ITR Manifold? (Ruby Civic)
Bigger TB will give you a little better Throttle Response, but I think the Induction system is more important.
If you go with a 70mm TB go with one tapered to Stock Diameter. This will encourage a Venturi effect.
Much like the J's Racing Intake does.
What kind of Cams are you running? What kind of Compression? Reguardless of how big the TB you engine will only flow as much air as it is setup up for.
to overly simplyfy this if you change nothing about the engine and increase the TB size by say 25% then you will reach WOT 25% earlier. So at 75% throttle your engine is already taking in as much air as possible and there is no increase between 75%-100% Okay I hope this is clear.
However if you have done a good amount of work to the engine o allow it to want to take in a larger volume of air then the above doesn't apply or maybe just to a degree.
itr1244
Jul 9, 2018 06:33 PM
Double Agent
Dec 29, 2008 07:44 PM
EleanoR
Sep 10, 2007 01:41 PM
michael O
Nov 11, 2003 12:25 AM
civicjdmb16a
Jul 8, 2003 02:02 PM
