Oil seals on tranny??
I am getting a little bit of gear oil comming out of the transmition, and I think it is the seals. The oil collects at the bottom of the transmition, but the leaking never gets too bad. You all say the I need to replace them?
I want to put in my GM syncromesh damn-it!
Thanks ahead of time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC »</TD></TR><TR><TD CLASS="quote">the seals on tranny where the axles go are like $4 ea on autozone
get them and change them.... no biggy</TD></TR></TABLE>
I know that, just wanting to get opinions from everyone.
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 »</TD></TR><TR><TD CLASS="quote">it could also be the seal for the shift rod that goes into the tranny, that seal will go bad and oil will seap out everytime you select a gear!</TD></TR></TABLE>
how difficult is it to replace the shift-rod seal? mine is seeping... barely a drip hangin on the outside of the boot
get the part from the dealer, remove the shift rod ans stabilizer rods. you won't to drain the tranny, but place a oil pan below the tranny. using a flat head screwdriver, pry the old seal off the tranny. take the new seal and put a small coat of oil on it, place it on the tranny. using a socket that will fit on the inside part of the seal, hammer the seal back in the tranny(don't hit it too hard). one you do that, attach your shifter rods and your done!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 »</TD></TR><TR><TD CLASS="quote">get the part from the dealer, remove the shift rod ans stabilizer rods. you won't to drain the tranny, but place a oil pan below the tranny. using a flat head screwdriver, pry the old seal off the tranny. take the new seal and put a small coat of oil on it, place it on the tranny. using a socket that will fit on the inside part of the seal, hammer the seal back in the tranny(don't hit it too hard). one you do that, attach your shifter rods and your done!</TD></TR></TABLE>
cool... i'm gonna change that seal myself.. (before going to GM syncromess)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azroth »</TD></TR><TR><TD CLASS="quote">Yea, I need to do all the seals, But getting the pin out is going to be a bitch
man just get a pin punch and a BFH, and it will be out in no time
</TD></TR></TABLE>man just get a pin punch and a BFH, and it will be out in no time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azroth »</TD></TR><TR><TD CLASS="quote">You useually go from the top or bottom, and are you on a lift?</TD></TR></TABLE>
from bottom to top, on the floor! i just had to do it today, i installed my shift rod backwards!
you dont have to take the tranny apart to get at that seal... dam im doin that tomorrow... thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crXBoy69 »</TD></TR><TR><TD CLASS="quote">
you dont have to take the tranny apart to get at that seal... dam im doin that tomorrow... thanks</TD></TR></TABLE>
not at all, that seal stays on the outside of the tranny case. you push it into the tranny, not as hard as you might think
Kid-jdm-teggy
Transmission & Drivetrain
Sep 10, 2013 08:41 PM
danno33
Jun 16, 2008 06:39 PM
