sudden loss of clutch pedal pressure
Old Aug 25, 2003 | 06:52 PM
civcexcoupeblack's Avatar
Default sudden loss of clutch pedal pressure
I have an action 2md clutch. I put it in about 3 months ago. Today when i went out to my car, the clutch has play the first 3/4 of the push, before it engages. Before there was a little play, but not nearly this much. Driving makes it a little better. I plan on re-bleeding the clutch line, but any ideas on what is going on? no leaks...but perhaps that slave or master cylinder are going out? hlp plz
Old Aug 25, 2003 | 06:53 PM
MooreBoost's Avatar
Default Re: sudden loss of clutch pedal pressure (civcexcoupeblack)
Master and slave cylinders. Check both.
gmoore
Old Aug 25, 2003 | 06:55 PM
check for what?
Old Aug 25, 2003 | 07:04 PM
MooreBoost's Avatar
Leaks.....But you said you didnt have any didnt you? Then I dunno....
gmoore
Old Aug 25, 2003 | 07:13 PM
MaxSterling's Avatar
Default Re: sudden loss of clutch pedal pressure (tegunderpressure)
clutch cylinder is empty, fill her up
Old Aug 25, 2003 | 07:21 PM
93GSRB17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civcexcoupeblack &raquo;</TD></TR><TR><TD CLASS="quote">I have an action 2md clutch. I put it in about 3 months ago. Today when i went out to my car, the clutch has play the first 3/4 of the push, before it engages. Before there was a little play, but not nearly this much. Driving makes it a little better. I plan on re-bleeding the clutch line, but any ideas on what is going on? no leaks...but perhaps that slave or master cylinder are going out? hlp plz</TD></TR></TABLE>
my buddy had the same problem.. we played with he cluch line and all of a sudden it went back to normal.. has not happened since.
LSEGHATCH
May 2, 2006 06:18 AM
Nations Sickest CRX
Aug 30, 2005 03:53 PM
akteamster
10
Aug 13, 2004 04:13 PM
ibe2fly
Jul 10, 2004 03:31 PM
92civeg
Jun 29, 2003 12:49 PM
