how to fix code 14
once the CEL is triggered the thing idles crazy. it goes up then falls real quick like i let off the accelerator and then goes back up without letting my foot off. im thinking IACV??? any way to fix it?
Code 14 - Electronic Air Control Valve
Lets extra air into the intake manifold, to help control the idle under different loads.
Check the O-rings, for mountng condition.
Clean the inside of the Valve after removing, using any kind of solvent that will remove carbon build up. By spraying it inside the two holes ect...
Place the flat end of a screw driver on the EACV while the engine is running. Place the handle against your ear and listen. Should hear something in there jumping back and fourth at a rapid rate.
EACV Sensor Wires:
1 Blue/Black
1 Yellow/Black
EACV Sensor Wires:
1 Blue/Black
1 Yellow/Black
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx »</TD></TR><TR><TD CLASS="quote">Code 14 - Electronic Air Control Valve
EACV Sensor Wires:
1 Blue/Black
1 Yellow/Black </TD></TR></TABLE>
you have pm.
EACV Sensor Wires:
1 Blue/Black
you have pm.
