Toda Spec A power band?
Old Aug 15, 2001 | 12:31 PM
H23 Power's Avatar
Default Toda Spec A power band?
can anyone tell me the power band of the Toda Spec A cams...?
I really want a cam that idles normally, and it looks like the Spec B is out...i'd like to raise my revlimit, but don't find it to be worth it to just go to the 8400 R limit...anyone know when the A's stop makin power?
thanks
Old Aug 15, 2001 | 12:34 PM
sgT's Avatar
sgT
Default Re: Toda Spec A power band? (01GSR)
Tops out around 8000
take a look at my website for my spec A dynograph
Old Aug 15, 2001 | 12:38 PM
H23 Power's Avatar
Default Re: Toda Spec A power band? (sgT)
you ran a 12.7 with 207 hp to the wheels? thats pretty damn sweet
what else do you have?
Old Aug 15, 2001 | 12:42 PM
B18CXr's Avatar
spec A's will still have the "ON-OFF" type of power the stock cams produce.....because the low lobes "swirl" and are not as high as B's in profile.
Old Aug 15, 2001 | 01:07 PM
H23 Power's Avatar
Default Re: Toda Spec A power band? (B18CXr)
lets try this...
where should i set my redline?
Old Aug 15, 2001 | 01:09 PM
sgT's Avatar
sgT
8600-9000 is ideal.
And no I ran 12s with the Spec Cs. not As. Never got to run the As.
Speaking of ON/OFF, the wheelspin at vtec was insane.
Old Aug 15, 2001 | 01:16 PM
Splat's Avatar
Collector-o-Guns and Drinker
FWIW, I've been running B's since May, and now that they're tuned in, they are perfectly streetable. My car idles fine now, and would idle even better if I had a full exhaust. The key to running B's is to make sure your car can breathe. At mininum, that means JDM header, oversize cat, and your choice of airbox. Jack's car ran fine with the stock Type R airbox. I'm using an AEM.
Just get it tuned well and you'll be fine with B's. I was going to go the A route as well, but was talked out of it. Needless to say, I have no regrets.
Old Aug 15, 2001 | 02:27 PM
nsx-Animal's Avatar
Default Re: Toda Spec A power band? (itr009)
Hey itr009 did you install valve springs with your spec B's?
Old Aug 15, 2001 | 03:28 PM
mafay2's Avatar
New User
Default Re: Toda Spec A power band? (ITR-Animal)
My specB only give bad idle when the engine is tooooooooooooo hottttttttttttttt!!
Otherwise, it idle perfectly normal!!
Old Aug 15, 2001 | 05:04 PM
Toda Party's Avatar
Default Re: Toda Spec A power band? (mafay2)
1 - when do ITR cams stop making power?
2 - I'm trying to decide A's and B's, and my main dilemma is that I'm going to be driving back and forth from school to my house (400 miles) as well as locally everyday...I'm afraid running B's wouldn't be ideal here, as well as not helpful to my mpg...
Old Aug 15, 2001 | 06:30 PM
sgT's Avatar
sgT
Default Re: Toda Spec A power band? (NBP ITR 01-622)
I get 27-30mph combined with spec Cs and large injectors.
30+ easy on highway only.
Old Aug 15, 2001 | 06:33 PM
Splat's Avatar
Nope. Running stock ITR valvetrain. I don't plan on raising rev limiter.
Old Aug 15, 2001 | 07:59 PM
TypeC's Avatar
Holy $hit, so you went from a 13.5ish@100 to a 12.5@130?
j/k, I rode in an ITR with spec B's and the idle was fine. -C
Old Aug 16, 2001 | 06:20 AM
Splat's Avatar
I went from 23-24 mpg to 30-32 mpg after my B's were installed.
Old Aug 16, 2001 | 06:35 AM
Back in Black's Avatar
Rather OG
I'll be running the B's along with Toda inner/outer springs as I'll feel more safe with them. Also, in the future, I'll always have the option to raise the limit if I choose to. I tell ya, looking at those cams sitting in the apartment is enough to drive you crazy
[Modified by Darth VadeR, 10:35 AM 8/16/2001]
Old Aug 16, 2001 | 06:54 AM
B18CXr's Avatar
I averaged 33mpg when I had my B's.......If the tuner is competent, B's are perfectly streetable, the key is the low throttle fuel maps....................................
Old Aug 16, 2001 | 07:06 AM
Willard's Avatar
lub lub lub lub lub lub lub lub lub lub lub lub lub lub lub lub lub lub lub lub
one day....
WIllie
Old Aug 16, 2001 | 07:37 AM
Splat's Avatar
Default Re: Toda Spec A power band? (Darth VadeR)
So you already have the cams?!? You better get 'em in there soon!!
I will upgrade the valvetrain in time. It is not a priority at the moment, however.
Old Aug 16, 2001 | 07:39 AM
Rather OG
Yeah, they've been there for 2 weeks! It's enough to drive you mad. Holding off until the valvetrain arrives. Then can do all at once
Old Aug 16, 2001 | 07:53 AM
Splat's Avatar
Good point. No sense in yanking everything apart twice, now is there? Say, you gonna need a cut valve cover for tuning?!? I just happen to have one laying about the pad...
Old Aug 16, 2001 | 12:26 PM
Nick248's Avatar
So what about the A's????? It seems as if everytime a question about the A's comes up, all you get is "look at mine .... my spec B's!!"
Can anyone stick with the topic??
Thanks
-Nic
Old Aug 16, 2001 | 12:28 PM
H23 Power's Avatar
Default Re: Toda Spec A power band? (Nick248)
agreed....i'm still lookin at the A's...
Old Aug 16, 2001 | 12:35 PM
B18CXr's Avatar
refer to the 2nd, 4th, 6th posts. in a nutshell, similar low end as stock with a "kick" at x-over, much harder than stock while running out of air a little after 8K. Steve's plot shows this...
Old Aug 16, 2001 | 12:53 PM
Nick248's Avatar
Thanx b18CXr - Running out of air alittle past 8000 is very similar if not the same as the stock cams correct? Stockies loose power alittle after 8000 correct?
So is it safe to assume that the power curve will look similar to stock just that after the x-over point, hp curve would be greater?
OK I looked at sgt's graph and cannot determine which curve pertains to the spec a's.
Nick248
[Modified by Nick248, 2:07 PM 8/16/2001]
Old Aug 16, 2001 | 10:15 PM
H23 Power's Avatar
yeah, the graphs aren't labled very well
