Can you swap out the dash from an canadian Si??
Old Aug 25, 2003 | 05:14 PM
allicedout's Avatar
Default Can you swap out the dash from an canadian Si??
I have a 91 civic dx without the tach and i wanna replace it with a factory dash out of a canadian Si. I've heard its a straigh bolt in?? Is that true?? Or do I have to do sum wiring mods?? Thanks
Old Aug 25, 2003 | 06:05 PM
Kyo Babic's Avatar
Default Re: Can you swap out the dash from an canadian Si?? (allicedout)
it should be bolt in, i dont see why it wouldnt be
Old Aug 25, 2003 | 06:21 PM
tysf's Avatar
if you want a tach all you need is the gauge cluster
it bolts right in and plugs right up but be sure to get the right year 88-89 and 90-91 are different
a crx cluster will work too btw
Old Aug 25, 2003 | 06:46 PM
Jay J's Avatar
Prince of Zamunda
Default Re: Can you swap out the dash from an canadian Si?? (tylerspec)
I don't see a problem. Why not just get a cluster. Also are the years correct?
Old Aug 26, 2003 | 03:40 PM
allicedout's Avatar
thanks for the help. I wanted to know if it was a straight plug in, and i guess it is. thanks
1991CIVICHATCH
Nov 15, 2013 02:45 AM
Black_89
Mar 5, 2013 02:51 PM
arigatocivic
16
Feb 20, 2009 05:19 PM
CRX91SE
Feb 15, 2008 12:18 AM
STHPERFORMANCE
Oct 14, 2003 01:44 PM
