how big can you go in a SOHC?
Old Aug 25, 2003 | 03:32 PM
GSRswapandslow
Guest
Posts: n/a
Default how big can you go in a SOHC?
Ok, i'm going to build my single for boost. I'm goin with a d15 crank and long rods. I'm also goin to sleeve it while doing this. How big of a bore do most ppl got? All I'm seein is 77mm....is that it?
Old Aug 25, 2003 | 03:39 PM
liam821's Avatar
25 Year Member
Default Re: how big can you go in a SOHC? (GSRswapandslow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRswapandslow &raquo;</TD></TR><TR><TD CLASS="quote">Ok, i'm going to build my single for boost. I'm goin with a d15 crank and long rods. I'm also goin to sleeve it while doing this. How big of a bore do most ppl got? All I'm seein is 77mm....is that it?
I recommend NOT using the d15 crank. The d15 crank has small main/rod journals. The larger bearings (in the d16) is going to help keep the motor together in a high hp application.
And you can go as high as 79mm or even 80mm, but with a turbo applicaiton its not recommended for strength. The highest golden eagle recommends is 77mm in a boosted application.
If you really want power outa a d-series, use a d16, sleeve it to 77mm, 10:1 pistons, port the head like only monica lewinsky knows how, use a huge turbo and boost it to the moon.
liam
Old Aug 25, 2003 | 03:47 PM
M.A.R.C.'s Avatar
Default Re: how big can you go in a SOHC? (liam821)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 &raquo;</TD></TR><TR><TD CLASS="quote">
port the head like only monica lewinsky knows how</TD></TR></TABLE>
dood... i LITERALLY fell off my chair laffing at that one hahahahahahahahah
Old Aug 25, 2003 | 03:53 PM
GSRswapandslow
Guest
Posts: n/a
actually, all the fastest SOHCs run the d15 crank
there are two different cranks. one large and one small.
and the reason i'm going to use it is so i can run a long rod and actually rev it and make power, unlike 99% of ppl that build them, i'm doing it RIGHT.
so, 77mm seems to the be the limit? Guess I'll have to find out....i'm thinking about 79mm, 10.5:1, and a larger turbo..maybe a straight t4.
but thanks for the help
Old Aug 25, 2003 | 03:54 PM
GSRswapandslow
Guest
Posts: n/a
ohh, and RLZ will be building, sleeving, and doing the head work...cause, they are the BEST YOU CAN GET!!!!!!!!
Old Aug 25, 2003 | 03:55 PM
liam821's Avatar
25 Year Member
Default Re: (GSRswapandslow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRswapandslow &raquo;</TD></TR><TR><TD CLASS="quote">actually, all the fastest SOHCs run the d15 crank
there are two different cranks. one large and one small.</TD></TR></TABLE>
I was under the impression that all the d15 cranks had small main/rod journals. Which d15 crank are you going to be using?
liam
Old Aug 25, 2003 | 04:26 PM
Stewie's Avatar
but thanks for the help</TD></TR></TABLE>
A low rod ratio is actually good in turbo application. You could use the extra displacement too.
What were you planning to deck it or use an aftermarket crank?
Old Aug 25, 2003 | 05:04 PM
GSRswapandslow
Guest
Posts: n/a
stock 1.5l crank on the y8 block
and i need a r/s that will allow RPM.
RPM is whats holding most SOHC's back.
Old Aug 25, 2003 | 05:41 PM
ladysman's Avatar
liam</TD></TR></TABLE>
To add, 78mm is the highest Endyn recommends. That is what mine is. Sleeved by Golden Eagle
Old Aug 25, 2003 | 05:43 PM
GSRswapandslow
Guest
Posts: n/a
that's not true at all
the factory valves are so light...all you need to replace is the retainers and you're fine.
and it'll rev to maybe 9 or so
Old Aug 25, 2003 | 05:44 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRswapandslow &raquo;</TD></TR><TR><TD CLASS="quote">that's not true at all
and it'll rev to maybe 9 or so</TD></TR></TABLE>
I have heard that too. I went ahead and put Ferrea stuff in though.
Old Aug 25, 2003 | 05:47 PM
GSRswapandslow
Guest
Posts: n/a
i'm going to use Zex retainers...since that's what my engine builder reccomended. They had a fast SOHC too....12.0 with a 15g.
but, i think i'll just use his valve springs too...since he's got some good ones for CHEAP
Old Aug 25, 2003 | 05:48 PM
GSRswapandslow
Guest
Posts: n/a
Default Re: (AzCivicCpe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzCivicCpe &raquo;</TD></TR><TR><TD CLASS="quote">either way, 9k isnt enough?</TD></TR></TABLE>
what????????????????????????
Old Aug 25, 2003 | 06:01 PM
GSRswapandslow
Guest
Posts: n/a
and i said maybe around 9
whatever Brad tells me I need to
Old Aug 25, 2003 | 06:10 PM
tek_civic's Avatar
a friend of mine has a zex powered d16t full zex cam, zex springs, zex retainers. and he revs to 9k, needless to say that he has gone through 3 heads with 2 engines. i wouldn't reccomend going to 9k on a d series, but maybe.
Old Aug 25, 2003 | 06:18 PM
GSRswapandslow
Guest
Posts: n/a
mine will be built better
Old Aug 25, 2003 | 06:33 PM
gitwidit's Avatar
just for reference, on a d16z6 refreshed factory head with new oem springs I hit valve float in the are of 8k on the dyno.
Old Aug 25, 2003 | 06:37 PM
GSRswapandslow
Guest
Posts: n/a
agreed
that's why to go over you get some of Brad's valve springs
Old Aug 25, 2003 | 06:42 PM
Joseph Davis's Avatar
Cam profiles can also dictate how well the spring can keep up.
And RZL can back GSRswapandslow's line of **** if he can come up with the money. Time to get two jobs, Rob, and dance fatboy dance. You still owe me $65, stunna!!
Old Aug 25, 2003 | 06:46 PM
GSRswapandslow
Guest
Posts: n/a
one GOOD job....hopefully
and the manwhoring
Old Aug 25, 2003 | 06:55 PM
D-Man's Avatar
Default Re: (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">Cam profiles can also dictate how well the spring can keep up.
Yes..I spun one of my NA D16Zs as high as 8800 rpms with nothing more that a gude gorilla cam....but...it didnt run any quicker than shifting it at 7500rpm and was only slightly quicker than a stock D16Z cam,like .01 improvement in ET but it was cool reving it that high
BTW..what's holding back Ds is its Head Flow.
Old Aug 25, 2003 | 06:59 PM
GSRswapandslow
Guest
Posts: n/a
i'll be going with bigger valves and i'll have one of the baddest SOHC heads on EARTH, literally
Old Aug 25, 2003 | 07:08 PM
D-Man's Avatar
Your best bet might be to go with a D16A6 head,I never saw a D make more power than james wests 511whp D16A6 and also the quickest NA D was running a D16A6 Head...Bisi..that's just something to think about
Anyway..what is your goal with this motor? to be the 1st to break 9s or something?
Old Aug 25, 2003 | 07:52 PM
GSRswapandslow
Guest
Posts: n/a
i just wanna run 11's dude...
i could care less about records. I'll be building another b sereis sometime....so this is just to mess around with
Old Aug 25, 2003 | 08:12 PM
D-Man's Avatar
for 11s all you need is a nice fresh stock D16A,Y or Z head..oversize valves and porting would be a waste..just ask BoostedED9 or Zex Man
