Qick CAI question... HELP!!!
Old Aug 25, 2003 | 03:31 PM
Drum_Guru's Avatar
Default Qick CAI question... HELP!!!
I am installing an aftermarket CAI on my 98 lude... there is a little vaccum hose going to a butterfly valve in the stock air box... what the hell do i do with it? Do I just tie it shut?
Old Aug 25, 2003 | 03:38 PM
Drum_Guru's Avatar
Default Re: Qick CAI question... HELP!!! (Drum_Guru)
instead of just reading this... try to answer...
Old Aug 25, 2003 | 03:47 PM
Sticky Tires's Avatar
* B A N N E D *
vacuum cap. or check out this link http://www.ntpog.org/mods/fift...shtml
or if your lazy, i researched for you. read this
If you opt not to remove the vacuum lines and related equipment, tie off or plug the vacuum line that was going down to the butterfly valve; doing so will help to keep your vacuum up to snuff and keep crap out of your engine.
Old Aug 25, 2003 | 04:07 PM
Silverprelude98's Avatar
I know of the one you are talking about, it is part of the resonator under the passenger-side fender that weighs like 3 lbs, has a butterfly vacuum switch on it, I didn't do anything with it but take it all off, but follow the website provided above.
Modified by Silverprelude98 at 1:21 AM 8/26/2003
K_1
14
Aug 23, 2007 06:14 AM
Homesickelian
Nov 18, 2006 09:55 AM
carbonlaced
Apr 29, 2006 09:26 AM
Variance
Jan 25, 2002 05:27 AM
GSRpower
Oct 23, 2001 06:45 AM
