any cam gears for a zc motor?
i have a friend that has a zc and web cams and he was told that no companies made cam gears for the zc. is this true? do any other cam gears work? thanks
use AEM cam gears for a b series motor. they work, i know 1st hand as i had them on my car for over 2 years with no problems. no need to trim anything or shave down material.
check: http://www.thezcr.com there is a link there for takaira or something to that effect- it is the only place to buy new cam gears for teh ZC that I am aware of. You can use B series gears, but I have been told there is some "shimming" involved.
I used the AEM gears...I had them shaved, because if you don't then the belt hangs off a bit off the back of the gear.
But it will work without shaving them...but if you want to shave em just bring them to a machine shop and tell them you want the B gear to sit like the stock gear.
sorry lost all my pics...been a while since I had my dohc zc this is the back of my shaved aem
