Brake Noise
Old Aug 15, 2001 | 11:17 AM
DavidGSR's Avatar
Default Brake Noise
I've been having a problem with my brakes that doesn't seem to affect performance at all. First it is a '94 GSR with 95K miles. On the front brakes if I am rolling backwards and apply the brakes I hear a "click" or "tap". If I do it a second time it doesn't make any noise. Then if I move forward after having rolled backwards, the 1st time I apply the brakes I hear the same noise again. After that I don't hear it again (until I apply them when the car rolls backwards). It sounds to me like the pads are shifting in the calipers. Anyone have any ideas? Is this a common problem? I have changed the pads at 50K myself.
P.S. My wife's '94 Accord had the same problem on the rears before we sold it.
Old Aug 16, 2001 | 05:10 AM
DavidGSR's Avatar
Default Re: Brake Noise (DavidGSR)
Anyone?
Old Aug 16, 2001 | 01:11 PM
DavidGSR's Avatar
Default Re: Brake Noise (Teken)
No, it pretty much happens all the time. I don't think it has anything to do with flash rusting of the rotors. It sounds like the pads shiftina inside the calipers. When I replaced the pads at 50K I didn't replace the retainer spring (correct name?). Don't know if that matters.
Old Aug 16, 2001 | 03:07 PM
Rainmaker's Avatar
what is flash rusting? This might be occurring on my GSR... It sits on the edge of a hill with a lot of humid wind blowing at it constantly.
Rainmaker
Old Aug 16, 2001 | 04:32 PM
Chris's Avatar
Yes, the pads are just shifting. Perfectly normal!!!
Old Aug 17, 2001 | 04:17 AM
DavidGSR's Avatar
Default Re: Brake Noise (Rainmaker)
Flash rusting is very normal on brake rotors. I see it happen when it is parked and it rains or after I wash it. You can see the rust on the rotor surface. Doen't seem to cuse a problem. As soon as you apply the brakes it is generally gone. You may hear a slight grinding noise the first stop or 2 though.
By the way, I noticed that the "shifting" problem seems to be noticeable when the brakes are cold. Glad it isn't a problem. Thanks for the feedback Chris / Teken.
97CWITR
Jan 8, 2010 04:24 PM
Landshark68
Apr 20, 2007 10:01 AM
dohc_profile
Jan 30, 2007 09:24 AM
96teggynonVtec
Apr 13, 2006 05:30 PM
mickey513
Feb 4, 2003 09:36 PM
