tiny 'lil' bulbs in climate control
is there a specific name for them...or what is the wattage/volts for them...i took the one out for my defroster switch(the one that lights up when the headlights are turned on) and it looks like a bulb from x-mas lights but smaller...just the bulb with the real fine/thin metal wires...im gonna try some electronic stores to get a couple..i.e. radio shack...
i know im not the only one who needs them either...
Don't bother loooking in any stores. The only place I could find them is from Honda/Acura.
BTW the bulb in your defrost and emerg. flasher switches are smaller than the ones used in the climate control. When you order them, the come with that plastic base. In my last order from Carland Acura I went ahead and got 4 bulbs for the climate control (enough to replace all of them) and 1 bulb for my emerg. flasher switch.
i cant even find them on http://www.acuraautomotiveparts.org..
but i was looking a radio shacks website and they had a similar bulb..style was the same just th bulb was bigger and i called and asked if they have those in smaller sizes and the guy was like sure....so i dunno im might just check what he has ...how much did they run u from the dealer...?
Here we go:
#1 in the diagram, description says T4.2 so I guess 4.2 W, $3.12 each, 4 needed.
That diagram is under "Heater Controls"
Here's the emerg. flasher and defroster buttons:
#9 in the pic, $5.16 each, 1 per switch (it doesn't tell the wattage, but they are smaller than the ones used in the climate control).
does your hazard button light up when the headlights are on at night...or just when u put the hazards on...mine only light up when the hazards are on...thanks patrick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg-your-it »</TD></TR><TR><TD CLASS="quote">does your hazard button light up when the headlights are on at night...or just when u put the hazards on...mine only light up when the hazards are on...thanks patrick</TD></TR></TABLE>
Mine lights up with my accessory lights.
The red triangle should light up when parking lights and/or headlights are ON.
Good Luck, finding the bulbs for those switches, though. ALL the ones I ordered were TOO BIG. Finally, just bought the whole switch off of ebay for $4-5. LOL
eurocrx
Oct 17, 2010 12:05 AM
eghatchomar
Mar 28, 2005 08:07 PM
