higest compression on pump gas(93)
Old Aug 25, 2003 | 06:37 AM
ping83's Avatar
Default higest compression on pump gas(93)
i have a b18c that i want to do a stroker kit to. i already have the head done with jun 3's and i want to do the bottom end. i was wondering what is the highest compression you can go safely with 93 octane bp gas or shell. any help would be appreciated.
Old Aug 25, 2003 | 07:28 PM
TwoRedEGgs's Avatar
Default Re: higest compression on pump gas(93) (ping83)
well i think as long as you have something like hondata to tune it well then i think you should have no problem running a little over 12.1, but then again i'm in cali and ,y pump gas is good old 91 so i dont konw the exact #'s. But it is all in the tunning, tunning can make your car do wonderful things !
Old Aug 25, 2003 | 08:23 PM
PHO-SHIZZLE's Avatar
I've seen 12.5:1 but thats with some good tunning and a good air fuel mixture
Old Aug 26, 2003 | 07:45 AM
ping83's Avatar
Default Re: higest compression on pump gas(93) (dailydriven)
are you running 93 octance pump gas or are u having to add an octane booster. Also, how is the reliablitly of the motor with that high of compression and if you have any dyno carts with high compression that would be helpful. thanks, matt
Evolsport
Jul 17, 2009 12:44 PM
jdmb16ef8
Aug 19, 2007 03:10 PM
ErikDaGenErik
12
Apr 9, 2005 09:33 AM
90da4dr
Mar 7, 2003 09:36 PM
Pinhead
Jan 31, 2002 09:44 AM
