how to fix f*cked up locks?
Old Aug 25, 2003 | 03:24 AM
trooper0641's Avatar
Default how to fix f*cked up locks?
Today, my friend tried opening my door by pulling on the handle as i was trying to unlock the lock from the inside. (i have a 92 cx) Well...the lock just all of a sudden got loose? and doesnt click anymore...if i was going to lock my door i would have to lock it with a key from the outside. is there anyway to have this fix?
Old Aug 25, 2003 | 06:17 AM
Damon's Avatar
the lock rod could have came off, or the remote broke. take off the door panel and take a look.
Old Aug 25, 2003 | 07:30 AM
rolow's Avatar
Default Re: how to fix f*cked up locks? (trooper0641)
the inside handle breaks real easy. Where the rod from the lock mechanism attaches to the inside door handle is the most likely problem.
#5 & 19
http://www.hondaautomotivepart...+LOCK
Old Aug 25, 2003 | 10:45 AM
Default Re: how to fix f*cked up locks? (rolow)
should i take apart the door panels? i try to fix it somehow?
Old Aug 25, 2003 | 10:47 AM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
That happened on my driver's side lock. I just left it that way so if some thief tries to unlock the door by pulling back the window, they'll have to use the passenger's side.
Old Aug 25, 2003 | 11:00 AM
rolow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 &raquo;</TD></TR><TR><TD CLASS="quote">should i take apart the door panels? i try to fix it somehow?</TD></TR></TABLE>
Take off part #7/ 20
there is one screw then it slides out.
then you should be able to see if #5 / 19 is broken
Old Aug 25, 2003 | 01:10 PM
A OK! anyone else with some good advice? ttt
Old Aug 25, 2003 | 02:13 PM
SilverJdmhatch's Avatar
nothin else you can do besides check that........my car and a freinds del sol are the same way on the drivers side door so i think honda used cheap parts on the door handle/lock assembly i just left it it doesnt bother me
Old Aug 25, 2003 | 09:35 PM
Default Re: how to fix f*cked up locks? (SilverJdmhatch)
ttt anymore advice?
Old Aug 25, 2003 | 10:41 PM
arg! ttt
Old Aug 26, 2003 | 12:24 AM
Sketch_hs's Avatar
hit your friend first of all
take apart the door see what's broken.
it's not that hard just make sure you don't break any of the little plastic things that keep the panel on!
good luck.
-Sketch
p.s. smackem good!
Old Aug 26, 2003 | 12:38 AM
92 civic VX B18c's Avatar
HT Black Ops
Default Re: how to fix f*cked up locks? (SkyeC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkyeC &raquo;</TD></TR><TR><TD CLASS="quote">That happened on my driver's side lock. I just left it that way so if some thief tries to unlock the door by pulling back the window, they'll have to use the passenger's side. </TD></TR></TABLE>
It's that way on both my doors. One night my old roomate pulled up while some kick was taking my stereo, my roomate said he almost killed himself trying to get out fast enough to get away. After the kid got out, he jumped onto the back of his buddies car and drove off. My roomate came into the house laughing his *** off and said, Dude some kid was just inside your car and it was the funniest thing" I didn't find it funny, now that i think back on that night I wished I could have saw it!
Old Aug 26, 2003 | 06:28 AM
Smith Wise's Avatar
same thing happened to me. someone should have told you to search but they're being nice.
check out my post.
https://honda-tech.com/zerothread?id=593924
vacantskies88
Feb 25, 2008 07:41 PM
MetalHead4454
Nov 2, 2005 10:20 AM
FK00GSR
Apr 10, 2005 06:32 PM
SilverDc2
Mar 31, 2005 07:00 PM
