Ground Control Coilovers. I forgot how I adjusted them. Can you help?
Old Aug 24, 2003 | 09:41 PM
crxforum's Avatar
Default Ground Control Coilovers. I forgot how I adjusted them. Can you help?
I installed mine a while back with some of my buddies and I totally forgot how we adjusted them after we got them installed. I want to lower my back end about 1" more and adjust both sides because the passenger side is about 1" lower than the driver side even with me in it. Any help would be great.
Thanks
CRX Forum
Old Aug 24, 2003 | 09:45 PM
PSU's Avatar
PSU
formerly DxHatchback
Default Re: Ground Control Coilovers. I forgot how I adjusted them. Can you help? (crxforum)
they have an allen set screw. loosen that and they will be adjustable.
as for height, its basically guess and check
Old Aug 24, 2003 | 09:48 PM
crxforum's Avatar
Default Re: Ground Control Coilovers. I forgot how I adjusted them. Can you help? (DxHatchback)
So do you mean like I just measure the height now and then lower it an inch from the hight it is at now and then Im ok? Like if there is a 1" adjustment for lower it will be 1" lower when they settle?
CRX Forum
Old Aug 24, 2003 | 10:02 PM
ransack's Avatar
You use the given allen wrench that came with the set. If you dont have it, just find the correct size. Moving the support one inch down will lower the car one inch down. Simple enuff
Old Aug 24, 2003 | 10:57 PM
FcUK It.'s Avatar
stoner
Old Aug 24, 2003 | 10:59 PM
bryant's Avatar
Default Re: Ground Control Coilovers. I forgot how I adjusted them. Can you help? (ransack)
or count the rings and match on both sides.
BLANCOh22a4
Honda S2000
Mar 23, 2011 07:05 PM
NyPosterBoy
Suspension & Brakes
22
Mar 11, 2010 06:31 PM
wite2nr
Suspension & Brakes
Jan 6, 2010 09:11 AM
white4doorsi
Feb 15, 2005 07:19 PM
Red_Si
Jun 25, 2003 09:41 AM
