had a bad install on itr cams
Old Aug 24, 2003 | 09:22 PM
One Bad GeeSeeR's Avatar
Default had a bad install on itr cams
well i got my itr cams yesterday. so i decided to put them in today. everything went in fine. but stupid me i forgot one nut on the cam gear cover. so it felt all the way down to the crank pully. so not knowing it fell down. i attempted to start the car. then A BIG CLANK! but i didnt start the car. i immediatly stop the car. looked around saw nothing. so i remove everything again. started to hand crank the pully and it was soo hard to do. belt didnt jump a tooth so i guess i was lucky that the belt didnt skip a tooth so timing was okay no piston to valve contact. then i saw the belt, and it was shredded thats when i knew the bolt was there. grrr. bought a belt when i was about to change the belt. i saw this.
that bolt did that to the crank pully. grrr. stupid me. now i am waiting till tomorrow to order the part.
cliff notes: tried to install cams, left a bolt in the timing belt area, broke crank pully.
Carlo
Old Aug 24, 2003 | 09:24 PM
DEVIN22CBR's Avatar
Default Re: had a bad install on itr cams (One Bad GeeSeeR)
OUCH!!! Not good bro ..
Old Aug 24, 2003 | 09:27 PM
IN VTEC's Avatar
Just make sure you get the correct part for OBD-2 motors with CKF sensor.
Old Aug 24, 2003 | 09:32 PM
DVC2008's Avatar
Default Re: had a bad install on itr cams (IN VTEC)
ouch I had that happen to me once took me all day to get the bolt out damn.
Old Aug 24, 2003 | 09:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Just make sure you get the correct part for OBD-2 motors with CKF sensor.</TD></TR></TABLE>
Its the one with the backing right? i seen the obd1 motor gears that its just the gears. so i am assuming that the obd2 motors the sensor reads the backing part right?
Carlo
Old Aug 24, 2003 | 10:00 PM
SiR831's Avatar
that sucks
good luck though
Old Aug 24, 2003 | 11:46 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
ouch, that looks like it hurt :-(
Old Aug 25, 2003 | 12:26 AM
integraL's Avatar
Default Re: had a bad install on itr cams (dLo GSR)
ouch im thinking of getting itr cams...should i have a shop install it?
Old Aug 25, 2003 | 12:54 AM
Default Re: had a bad install on itr cams (integraL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraL &raquo;</TD></TR><TR><TD CLASS="quote">ouch im thinking of getting itr cams...should i have a shop install it?</TD></TR></TABLE>
no just be careful and thorough. took me 3 hrs, with no prior experience. no problems thus far, and that was 10 months ago.
Old Aug 25, 2003 | 07:47 AM
IN VTEC's Avatar
Yes.
The OBD-1 gears don't have the extra set of teeth on the back, just the driver gear for the timing belt.
Old Aug 25, 2003 | 07:56 AM
MyLittleRedCar's Avatar
my condolences.
Old Aug 25, 2003 | 04:03 PM
Default Re: (MyLittleRedCar)
Update: Lucky me today, i headed out to the Acura Dealership in Oakland to order my Crank pulley gear. And the parts guy was like " ooh i have one in stock" YES!!! no more waiting for me. cost me like 60 dollars thought ouch. , oh well its was my fault anyway. soo i get the part. and started to work on my car. changing the timing belt and finishing up the install. started the car. whoo hoo runs like a champ. now for the test drive on the itr cams, i set my vtec point with my fields controller to 5000, omg it was crazy. i noticed a slight loss in low end but high end pulled stronger to my butt dyno, it really revs up all the way to redline.
Overall itr cams are a good bang for the buck mod. next in line are skunk2 manifold and jdm itr header.
Carlo
Old Aug 25, 2003 | 04:11 PM
mr.beeks's Avatar
Default Re: (One Bad GeeSeeR)
I guess you were excited that you were done
it happens to all of us!
but im glad to hear that you are done and you are satisfied..
Old Aug 25, 2003 | 04:17 PM
n0 iNTegRiTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by One Bad GeeSeeR &raquo;</TD></TR><TR><TD CLASS="quote">Update: Lucky me today, i headed out to the Acura Dealership in Oakland to order my Crank pulley gear. And the parts guy was like " ooh i have one in stock" YES!!! no more waiting for me. cost me like 60 dollars thought ouch. , oh well its was my fault anyway. soo i get the part. and started to work on my car. changing the timing belt and finishing up the install. started the car. whoo hoo runs like a champ. now for the test drive on the itr cams, i set my vtec point with my fields controller to 5000, omg it was crazy. i noticed a slight loss in low end but high end pulled stronger to my butt dyno, it really revs up all the way to redline.
Carlo</TD></TR></TABLE>
That sucks about the 60 bucks, but at least you didnt have to wait for it to ship in, i guess
Old Aug 25, 2003 | 04:20 PM
drumnatural's Avatar
With proper tuning you can gain close if not just over 200whp. http://www.team-integra.net/fo...earch
Old Aug 25, 2003 | 04:39 PM
95gsr's Avatar
I was ging to say in my 95 gsr the back plate isn't there it's just the gear.
Old Aug 25, 2003 | 05:04 PM
JDM2ndGen's Avatar
Default Re: had a bad install on itr cams (95gsr)
with itr cams ...do you have to have the motor tuned after you install them?
Old Aug 25, 2003 | 05:08 PM
Default Re: had a bad install on itr cams (JDM2ndGen)
That above link I posted answers that question.
Old Aug 25, 2003 | 05:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM2ndGen &raquo;</TD></TR><TR><TD CLASS="quote">with itr cams ...do you have to have the motor tuned after you install them?</TD></TR></TABLE>
i am not going to tune them yet reason being i want to get skunk2 manifold, itr throttle body and jdm itr header, and cam gears. dont want to tune every time i get a new part, i rather tune them all together.
Carlo
Old Aug 25, 2003 | 05:10 PM
threatcon13's Avatar
New User
Default Re: (SilTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilTeg &raquo;</TD></TR><TR><TD CLASS="quote">With proper tuning you can gain close if not just over 200whp. http://www.team-integra.net/fo...earch </TD></TR></TABLE> lol..good joke dude.
Old Aug 25, 2003 | 11:15 PM
JDM2ndGen's Avatar
oh i got ya ...i was wondering this because everytime i see people talking about installing itr cams they never talk about having it tuned and etc...
Old Aug 26, 2003 | 08:29 AM
Bill Hook's Avatar
Perhaps you mean 200 BHP, instead.
Old Aug 26, 2003 | 11:48 AM
ECKOTYPER's Avatar
THAT REALLY SUCKS MAN, I GOT MY FINGERS CAUGHT IN THE CAR WHILE IT WAS RUNNING CAUSE I CUT THE CAM COVER AND THE CYLINDER CLOSSEST TO THE CAMS GEARS INJECTOR WAS LEAKING, SO I WAS MESSING WITH IT WELL I SHOULDNT OF DID THAT! HAD TO GO TO THE HOSPITAL MAN IT WAS NASTY MY RIGHT HAND RING AND MIDDLE FINGERS ARE SCARED FOR LIFE
Old Aug 26, 2003 | 12:08 PM
EL Vap133's Avatar
Yikes, that sucks man!
Old Aug 26, 2003 | 12:21 PM
JDM2ndGen's Avatar
Default Re: had a bad install on itr cams (EVIL_Vap133)
yea that really does suck
