check engine code 71-74 can it retard the motor?
Old Aug 24, 2003 | 08:38 PM
capcon83's Avatar
Default check engine code 71-74 can it retard the motor?
just like the topic says can codes 71, 72. 73, 74 retard the motor?
and are these codes for misfire?
Old Aug 24, 2003 | 09:06 PM
D's Avatar
D
Default Re: check engine code 71-74 can it retard the motor? (capcon83)
misfire in cylinders 1-4.
Old Aug 24, 2003 | 10:09 PM
capcon83's Avatar
Default Re: check engine code 71-74 can it retard the motor? (D)
would it retard the motor
Old Aug 24, 2003 | 10:15 PM
uNF$@#!'s Avatar
misfire in all 4 cylinders? naw....what would make you think that?
Old Aug 25, 2003 | 01:39 PM
capcon83's Avatar
Default Re: check engine code 71-74 can it retard the motor? (Soup ****)
i dont know cause im not pulling good 1/4 mile times at the track, or my sorry tires is the case
Old Aug 31, 2003 | 12:20 PM
JDM_ek9's Avatar
Hey did u figure out your problem yet??? I am misfiring 4th cylinder only code 74
I've changed wires/plugs/cap and next step is distributor.
1999 B18C1 in a 2000 hatch.
strider380
12
Nov 8, 2013 12:27 PM
ShagPower
Sep 18, 2006 09:31 AM
finest_GSR
Nov 19, 2005 10:30 AM
rukawa1one
Feb 15, 2005 05:53 PM
Shakes
Apr 18, 2004 07:20 AM
