front brake rotors
Old Aug 24, 2003 | 08:33 PM
dpmac10's Avatar
Default front brake rotors
Hey whats up will i'm trying to take my rotors off and at the same time change my cv boot but i'm having trouble getting the hub and rotore even off of the spindle. I have a 1996 accord lx 2 door. i have a book to tell my how and it not really saying much for my year it has it for a deffenrent one. and also do u think that it is my rotors are wharped when i'm goin 50+ and brake the stiring wheel shakes and stuff thats what a guy at honda said so i figured woud'nt hert to have them turned down.
Old Aug 24, 2003 | 09:40 PM
im_the_teacher's Avatar
Default Re: front brake rotors (dpmac10)
yeah, the brake rotor is warp.........and taking off the rotor is really hard on 97 down accord.....sum need to press out.....
go cut your rotor and you should be fine.
Old Aug 25, 2003 | 04:56 AM
D21X's Avatar
Default Re: front brake rotors (im_the_teacher)
getting your rotor cut only delays the warping. most likely u'll probably need new brake fluid and maybe even calipers.
to take off your rotors i suggest either searching for it here on honda-tech or going to hondasociety.com and searching there because i did a DIY there. goodluck!!!
Old Aug 26, 2003 | 03:40 PM
dpmac10's Avatar
Default Re: front brake rotors (D21X)
thanks for the help i'm looking in to it.
Old Aug 26, 2003 | 03:44 PM
hondacb7's Avatar
i have a 90 accord and the rottors were bad i replaced them becuase they are a pain in the *** to get off. if u get noones you can beat the old aones off wiht a hammer and nothing has to be pressed back on i would suggest checking the wheel bearings at this time too .
ajtaccord
Aug 13, 2007 03:09 PM
Corruption
Jul 31, 2006 06:10 PM
lonefuzzy79
May 31, 2006 02:14 PM
Paul V
Jun 6, 2005 05:31 AM
seer_claw
Feb 24, 2004 08:13 PM
