Crank difference??
Old Aug 15, 2001 | 07:38 AM
Petah's Avatar
Default Crank difference??
Is there a difference between the ITR, GSR, or SIR crank? I heard that the ITR crank comes very balanced from the factory already and if this is true, this would make it the best out of the 3. But what about the GSR and SIR crank? Which one is better?
Old Aug 15, 2001 | 08:14 AM
3rdShift.org's Avatar
New User
Default Re: Crank difference?? (eg-six)
SIR crank has a shorter stroke, hence 1.6 liters w/ same 81mm bore. As for balancing, any crank is balanceable even after factory balancing. The cranks are not interchangeable between the blocks, so purchase a block w/ the displacement that you want and go from there.
Old Aug 15, 2001 | 08:53 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: Crank difference?? (3rdShift.org)
True that the B16 is different from the GSR/ITR. But only in stroke.
They (DOHC VTEC cranks) are interchangable.
For instance, the ITR and GSR are completely interchangeable. The B16 will fit in the GSR/ITR block, but you'd be de-stroking it to get a better rod ratio.
Essentially, the B16B (CTR engine) uses the B16 crank with special length rods in a GSR/ITR block to achieve it's almost perfect rod ratio.
HTH
MrXclusivE
Aug 7, 2009 11:13 AM
boosted91crx
Aug 4, 2009 11:12 PM
Mr HYDE
Dec 20, 2006 12:00 AM
0bd1_Kanobe
Apr 13, 2004 12:43 PM
bb6
Jun 3, 2003 06:44 PM
