When do i know i need an engine rebuild?
Old Aug 24, 2003 | 07:58 PM
Moonbus's Avatar
Default When do i know i need an engine rebuild?
Hi guys,
I feels like the engine is not very happy recently, and doesn't rev as freely as before.... can you tell me how do i know if i need an engine rebuild ? What kind of test I need to run to determine that?
Thanks!!
Old Aug 24, 2003 | 08:38 PM
REFLUX's Avatar
I believe excessive oil consumption is a good sign
not sure of the exact quantity of oil consumed tho....maybe 1quart/litre every 2000miles/3000km???
Old Aug 24, 2003 | 08:56 PM
vtec.dc2's Avatar
Default Re: When do i know i need an engine rebuild? (Moonbus)
whats done to the car and how many miles? do compression test, then leakdown.. make sure its not igniton components or other minor wear items (air filter) making it seem like you got something wrong with your engine.. any coolant/excessive oil loss? also.. do you get regular maintanace done (fluid change/valve adjustement)
Old Aug 24, 2003 | 10:23 PM
Moonbus's Avatar
Default Re: When do i know i need an engine rebuild? (vtec.dc2)
I bought it 2nd hand. The car now has 55000km on it, i bought it when it was a little over 50000km. Since then, I have change the tires, change oil to Speed Master (mobile 1 gone down very fast), changed all 4 spark plugs, and also transmission oil. I have not done any dyno test yet....
Please help me with more advise.
thanks!
Old Aug 24, 2003 | 10:40 PM
92TypeR's Avatar
FSAE
You have already been given some good advice. Compression and leakdown test will give you a huge idea on what is going on inside the engine.
Old Aug 25, 2003 | 12:49 AM
Spoond TEG's Avatar
Loss of compression, Worn Belts (Timing, Alt) Leaky fluids...
Great advice above. What part of tokyo are you in?
ashb82
Dec 20, 2011 03:22 PM
MrDomino
Dec 17, 2009 11:55 AM
Neutron
Apr 8, 2007 04:09 PM
gshockbreaker
Jul 28, 2002 12:06 AM
Perfectionist
Jun 16, 2002 05:31 PM
