B18C1 Dual-Stage IM
Old Aug 24, 2003 | 05:18 PM
00VTEC's Avatar
Default B18C1 Dual-Stage IM
as you guys already know, B16's and B18C5 comes with single-stage IM.
my question is, why did honda opt for dual instead of single on B18c1's??
what are pros and cons of having dual on B18c1 instead of single IM??
Old Aug 24, 2003 | 08:21 PM
mingchi69's Avatar
I to Smooch Pickle
Default Re: B18C1 Dual-Stage IM (00VTEC)
pro: better low end
con: hinders high end.
ITR, acura tried to make it as quick as possible, so they make a single runner intake manifold. That results in a quicker car.. but might not have as much torque as a gsr in the low end. (but i think it does.. because of the higher compression)
Old Aug 25, 2003 | 11:18 AM
dash's Avatar
Default Re: B18C1 Dual-Stage IM (mingchi69)
Honda spent alot of money on the 2 stage im for a reason, efintcey the im on the b18c1 is the best for the STOCK moder. when you start doing things like cams, porting and polishing....etc. you change the needs of the moder so the 2 stage intake does not function properly. ie a loss in power but if the moder is stock you will be extremely hard pressed to find one the will meat or beat Honda's intake manifold
Old Aug 25, 2003 | 12:54 PM
00VTEC's Avatar
thanks for the info
Old Aug 25, 2003 | 12:56 PM
TeamSTEALTH GSR's Avatar
just fyi, fastest n/a honda runs a gsr IM
Old Aug 25, 2003 | 10:47 PM
.xcalibur.'s Avatar
Default Re: B18C1 Dual-Stage IM (TeamSTEALTH GSR)
ERICKS racing's gsr manifold is completely bored and had the secondaries removed. So its technically a single butterfly design. But he will not release his secrets.
Old Aug 26, 2003 | 06:20 AM
Cone's Avatar
Default Re: B18C1 Dual-Stage IM (dash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dash &raquo;</TD></TR><TR><TD CLASS="quote">Honda spent alot of money on the 2 stage im for a reason, efintcey the im on the b18c1 is the best for the STOCK moder. when you start doing things like cams, porting and polishing....etc. you change the needs of the moder so the 2 stage intake does not function properly. ie a loss in power but if the moder is stock you will be extremely hard pressed to find one the will meat or beat Honda's intake manifold</TD></TR></TABLE>
spelling is your friend
at least you are right...
Old Sep 8, 2003 | 10:35 PM
mingchi69's Avatar
I to Smooch Pickle
Default Re: B18C1 Dual-Stage IM (Stealth 95 GS-R)
hahah..
efintcey - whats that??
moder - did u mean motor?
meat - meet u mean??
english 101..
Old Sep 9, 2003 | 12:16 AM
96dc2's Avatar
The GS-R IM was designed that way to maintain a broad and flat(ter than the ITR) torque curve. It's powerband is in the midrange compared to an ITR/B16.
Old Sep 9, 2003 | 04:12 AM
Charlie Moua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamSTEALTH GSR &raquo;</TD></TR><TR><TD CLASS="quote">just fyi, fastest n/a honda runs a gsr IM </TD></TR></TABLE>
STFU..... what a bold and unspecifyed statement... please post more intellgent remarks.
Ericks manifold is completely revamped and bored out to his specs. He must have done a lot of flow reasearch & development to that manifold. So basically he's only using the "shell" of that IM, inside is completely non-stock.
Old Sep 9, 2003 | 09:26 AM
Default Re: B18C1 Dual-Stage IM (Charlie Moua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">
He must have done a lot of flow reasearch & development to that manifold. </TD></TR></TABLE>
no ******* ****.... i didnt say it was "STOCK".... its still a ******* GSR IM.!
Old Sep 9, 2003 | 09:45 AM
juniordc2's Avatar
it was done for more midrange and a flatter torque curve as the others were saying, if you look at a dyno of a B18C1 and B18C5 overlayed together, the B18C1 makes more HP and torque than the B18C5 from 3k-6.5k, after that the B18C1 slopes down in power as the B18C5 literally spikes up.
jdmstyleEJ6
Feb 26, 2010 10:21 PM
BigPlansNoMoney
Feb 20, 2008 04:11 PM
AdrenalineRush
Nov 10, 2005 08:26 AM
43MA
Feb 6, 2003 04:50 AM
HotHB
Oct 23, 2002 06:36 PM
