loctite on flywheel bolts?
Old Aug 24, 2003 | 03:43 PM
MisterB's Avatar
Default loctite on flywheel bolts?
I have a clutchmasters 7.5lbs flywheel on my b16 and the flywheel bolts backed out.
Is it safe to use red loctite on the bolts?
Yes i did torque them to factory specs
Old Aug 24, 2003 | 03:57 PM
sackdz's Avatar
Default Re: loctite on flywheel bolts? (MisterB)
Yes.
Old Aug 24, 2003 | 06:37 PM
SDT Project EF's Avatar
Default Re: loctite on flywheel bolts? (sackdz)
yup
Old Aug 24, 2003 | 06:39 PM
mmuller's Avatar
Mad Scientist
Default Re: loctite on flywheel bolts? (SDT Project EF)
thats what i did
Old Aug 24, 2003 | 07:25 PM
blah13's Avatar
Default Re: loctite on flywheel bolts? (mmuller)
Its reccomended.
Old Aug 24, 2003 | 07:34 PM
MisterB's Avatar
Default Re: loctite on flywheel bolts? (blah13)
Ok will do
red loctite correct, and if i need to take it off i just use heat?
Old Aug 24, 2003 | 09:42 PM
Chaos69's Avatar
Use Blue locktite dude... Red will give you a LOT of problems taking them off when you need to.... Blue is recommended by most people and articles (Or medium)
Old Aug 25, 2003 | 12:41 AM
the DR.'s Avatar
i use red, and just take them off with an airgun, but heat might also work i suppose
Old Aug 25, 2003 | 01:11 AM
ExospeedAMcrx's Avatar
Default Re: loctite on flywheel bolts? (SlicedBread)
yup always use Loctite on the Flywheel bolts.
Old Aug 25, 2003 | 01:26 PM
MisterB's Avatar
Default Re: loctite on flywheel bolts? (exospeedAMcrx)
ok i will use the loctite but...
BLUE or RED
Old Aug 25, 2003 | 01:46 PM
VTECorona's Avatar
What is good to use on stuff such as valve cover nuts and such? Mine keep coming loose
Old Aug 25, 2003 | 02:32 PM
R6Elmo's Avatar
Default Re: loctite on flywheel bolts? (VTECorona)
BLUE. As I remember, the nuts aren't even torqued downt hat much
ramboPandA
May 4, 2016 09:54 PM
JDM EJ1 95
Jun 10, 2005 07:29 PM
bboylito
Apr 30, 2005 10:27 PM
H22A EG6
Dec 24, 2003 12:37 PM
Mikey3000
Nov 24, 2002 06:45 AM
