ITR rear O2 sensor?
Old Aug 24, 2003 | 02:23 PM
ITR981002's Avatar
Default ITR rear O2 sensor?
I just picked up #98-1002 on Wednesday. I had a test pipe laying around my garage from another project so I decided to get under the car and see what it would take to put it in. I've got 1 O2 sensor in the header before the cat, and it looks like that's the only one! I don't see any other O2 sensors in the cat at all..... I check the ECU thinking maybe someone converted it to ODBI already, but its a P73 ECU..... I don't have any CEL. I'm very confused......
Old Aug 24, 2003 | 03:03 PM
uNF$@#!'s Avatar
Default Re: ITR rear O2 sensor? (gothatch)
find where the secondary o2 wire/plug comes out, then trace the wires to the o2 sensor.
someone may have taken it out of the cat and wrapped it in foil or something as they too may have been running a test pipe.
Old Aug 25, 2003 | 09:38 PM
ITR#132's Avatar
Could be a chipped ecu. Mines dont have the second O2 anymore.
Old Aug 26, 2003 | 12:44 AM
PHiZ's Avatar
Default Re: ITR rear O2 sensor? (ITR#132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR#132 &raquo;</TD></TR><TR><TD CLASS="quote">Could be a chipped ecu. Mines dont have the second O2 anymore.</TD></TR></TABLE>
You have an OBD2 chipped ecu?
Does your CEL come on during start-up, I've seen ppl that have clipped/removed the bulb
Let us know if you find an O2 simulator.
-PHiZ
Old Aug 26, 2003 | 07:14 PM
ITR#132's Avatar
Default Re: ITR rear O2 sensor? (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">
-PHiZ</TD></TR></TABLE>
Yes I have a chipped/reprogrammed OBD2 P73 ecu.
Why would my CEL come on during start-up (Everyting is fine with my motor)?? Why clip/remove the CEL bulb, it still functions the same as an unchipped ecu.
I dont need an O2 simulator. The second O2 has been programmed out. (I have the second O2 sitting on the top shelf of my tool box)
OldSchoolFool
May 21, 2015 02:31 PM
Crider4_6
Engine Management and Tuning
Nov 14, 2011 04:26 AM
ncpk1234
Mar 18, 2009 06:40 PM
HONDA RR
Sep 16, 2005 03:53 PM
90hbvtec
Dec 5, 2003 07:42 AM
