Misfire problems PLEASE HELP
Old Aug 24, 2003 | 02:13 PM
SickGSR94's Avatar
Default Misfire problems PLEASE HELP
I have been in the garage for the last couple of days tryin to figure out what is goin on with my GSR. Its a 200+whp all motor setup. A couple of days ago rite outa the blue the car started to misfire at 1500-3000rpm then took off like nothing happened. It doesnt do it all the time. I am completely baffled over this. I checked everything from igniton to electronics and there are no problems... So I turn to you guys for help
Thanks....
Old Aug 24, 2003 | 02:15 PM
King_j's Avatar
Default Re: Misfire problems PLEASE HELP (SickGSR94)
you gotta list eh mods you have done, especially the ones done to ignition.
Old Aug 24, 2003 | 03:44 PM
SickGSR94's Avatar
Default Re: Misfire problems PLEASE HELP (King_j)
Mods...
HEAD: Port and Polish, AEM Tru Time Cam Gears, SKunk2 Valvetrain, SKunk2 High Compression Valves, SKunk2 Stage 2 Camshafts
BLOCK: Bored 20 over, Edged and Polished Crank, Eagle H Beam Rods, Endyn High Compression Pistons, Balanced and Blueprinted
Air/Fuel: V-AFC Apexi Controller, Skunk2 Type R Manifold Conversion with Type R Throttle Body, AEM Cold Air Intake, RC 310cc Injectors, B&M Command FLO FPR
Exhaust: DC JDM 4-1 Header w/ Test pipe, 2.5 inch cat back.
Old Aug 24, 2003 | 07:11 PM
WOTTEG's Avatar
I don't see that you changed anything with your ignition system for all that extra HP. Don't you need different plugs when you create more HP?
Old Aug 24, 2003 | 09:21 PM
user 996328629's Avatar
Default Re: Misfire problems PLEASE HELP (WOTTEG)
Check ur 02 sensor. Also check your fuel pressure....
Old Aug 24, 2003 | 10:27 PM
Audi A4's Avatar
Default Re: Misfire problems PLEASE HELP (Swags04)
also check for vaccum leaks and gap the plugs right
Z0831xiz
Dec 9, 2017 04:34 PM
Z0831xiz
Texas -OK -LA (Sales)
Dec 4, 2017 01:24 AM
sleepycivix
Dec 28, 2002 09:08 AM
sleepycivix
Dec 18, 2002 08:30 PM
sleepycivix
Dec 18, 2002 04:53 PM
