6th gen h22 accord fuel problems
Old Aug 24, 2003 | 01:51 PM
sal_blkej2's Avatar
Default 6th gen h22 accord fuel problems
the car does not want to start....fuel line is not kinked, has full tank of gas but it keeps on cutting off, why? he just got his p28 re-chipped but still had the problem before rechipping it...it will turn on from time to time but when you take it for a drive it starts bogging and hesitating like its gonna turn off....at one point while it was in neutral, he had the gas pushed in like at 2 grand and held it there but then it started to rev all crazy, up and down then shortly cut off....i really doubt its the fuel filter but am going to change it anyways....i was kind of wondering what are the chances of the fuel pump going bad? is there anyway to check it? if it is the fuel pump we will be replacing it with a walboro 255 pump....any help would be greatly appreciated....thanks, Sal
Old Aug 24, 2003 | 07:01 PM
sal_blkej2's Avatar
anyone?
Old Aug 24, 2003 | 09:47 PM
Bowlergi21's Avatar
Default Re: (sal_blkej2)
one of my buddies that we did an ls/vtec on had the same problem and it was the wire harness so you might want to try that.
Old Aug 25, 2003 | 05:02 AM
jweller's Avatar
Default Re: (Bowlergi21)
kind of an obvious Q, but is it throwing any codes?
Old Aug 25, 2003 | 02:42 PM
sal_blkej2's Avatar
hey jweller its actually on greenlions accord who just sold you the f23 head...anyways no its not throwing any codes with the rechipped p28.....still leaning towards fuel pump
Old Aug 25, 2003 | 06:18 PM
jweller's Avatar
yeah I kind of figured it was you guys
I'd say its definately not the fuel filter. the guy at Honda told me that the fuel filter is basically a lifetime part. you should never have to replace it unless somebody sugars your tank or something like that.
Old Aug 25, 2003 | 06:50 PM
sal_blkej2's Avatar
fuel filter was just a safe side thing, anyways so what are the chances of it being the fuel pump....after all he did change to using 93 octane everyday cuz of the h22....thanks, Sal
Old Aug 26, 2003 | 05:14 AM
jweller's Avatar
I'd be suspicious of any mechanical part failing after installing a rechipped ECU....
I'm not saying it couldn't be, but thats just my general feeling. It sucks to throw parts at a problem, although a walbro pump is a good part to throw at a car
I'd say check the pressure at the fuel rail when it's bogging and not starting. A bad pump would leave you with low pressure at the rail.
Old Aug 26, 2003 | 06:26 AM
v4lu3s's Avatar
RTFM
has he tested for voltage at the fuel pump?
Old Aug 26, 2003 | 01:37 PM
sal_blkej2's Avatar
havent did the volt test but will do before we going checking teh fuel pressure....anymore info, keep it coming.....thanks, Sal
Old Aug 27, 2003 | 05:19 AM
Jason kiDD's Avatar
Is the car missing when you rev it.. It could be a distributor problem. Timing could be off, bad spark plugs, wires, ignitor could be bad, alternator. There are many things that can cause what you are describing.. If your pump was bad then the car would buck..
Old Aug 27, 2003 | 01:00 PM
sal_blkej2's Avatar
well it is bucking....wires and plugs are new, distributor was recently changed from one of the best performance shops here so that shouldnt be a problem....not sure about the ignitor or timing??? thanks, Sal
MUGEN_EG95
Classic Hondas
Jun 5, 2008 12:50 PM
Dropped90Integra
Jul 26, 2005 05:09 AM
hotimportcrx
Oct 5, 2004 05:18 PM
krarthur
Jan 19, 2004 12:40 PM
HybridAccord
Sep 7, 2003 10:51 PM
