will a 99 b16a2 fit into a 88 crx hf?
Old Aug 24, 2003 | 01:22 PM
sal_blkej2's Avatar
Default will a 99 b16a2 fit into a 88 crx hf?
sorry my friend is a crx noob, anyways i know that b16a1's fit with the proper mount kit, shift linkage, etc. but how about the b16a2? if so what all will be needed? oh i tried to do a search for this specific model and swap but nothing....thanks, Sal
Old Aug 24, 2003 | 01:25 PM
Turbo Rex's Avatar
Default Re: will a 99 b16a2 fit into a 88 crx hf? (sal_blkej2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sal_blkej2 &raquo;</TD></TR><TR><TD CLASS="quote">sorry my friend is a crx noob, anyways i know that b16a1's fit with the proper mount kit, shift linkage, etc. but how about the b16a2? if so what all will be needed? oh i tried to do a search for this specific model and swap but nothing....thanks, Sal</TD></TR></TABLE>
All the same stuff as the b16a1, but you might want to convert to odb1 instead of odb2..
Old Aug 24, 2003 | 01:39 PM
sal_blkej2's Avatar
oh no doubt, he already has a mugen chipped p28 but if he does this i know that he'll need the obd-0 to obd-1 jumper.....so the b16a2 will fit the same way as an b16a1? thanks, Sal
Old Aug 24, 2003 | 03:38 PM
sal_blkej2's Avatar
bump
Old Aug 24, 2003 | 03:42 PM
Turbo Rex's Avatar
Default Re: (sal_blkej2)
oh yeah the b16a2 will bolt right in just like a b16a1
Old Aug 24, 2003 | 04:24 PM
Fred n J_v2.0's Avatar
Default Re: (Turbo Rex)
same motor but different tranny... the a2 has a hydraulic clutch operated tranny while the a1 has a cable clutch...
so you can use the a2, it while be the exact same bolt up as the a1 would but you would need to get a cable tranny
Old Aug 24, 2003 | 04:42 PM
civickiller's Avatar
Default Re: (95VXFRANK)
can he use the hydro flyhweel ? or does he need a cable styel flywheel ?
Old Aug 24, 2003 | 05:20 PM
the b-series flywheels should be the same...
Old Aug 24, 2003 | 07:03 PM
sal_blkej2's Avatar
thanks for the info guys....so does the cable tranny mount up the same? whast the difference, it uses a cable cluth but how about the shift linkage, is it different? thanks again, Sal
Old Aug 26, 2003 | 01:41 PM
sal_blkej2's Avatar
anymore info? thanks, Sal
tonyjdm
Jun 6, 2011 07:07 AM
Rudelude22
Jul 27, 2005 10:51 AM
lifesk8err
Apr 21, 2005 11:45 AM
im2pogi
Oct 4, 2004 06:10 PM
Wicked88
May 17, 2004 01:33 PM
