aftermarket suspension for the ELEMENT???
I believe that Sprint makes springs for the E. Check out http://www.hondasuv.com or http://www.hondaelement.org as they'll have the info you'll need.
thans for the info.
i'll go ahead and check that out
"Action without philosophy is a lethal weapon. Philosophy without action is worthless." Soichiro Honda
I Believe you can put stock 02 Civic springs on it and lower it 1.5-2.0. If this is true then coilovers for that vehicle should work as well, along with any other suspension components.
