stock shift knob
Old Aug 15, 2001 | 12:52 AM
tensai's Avatar
New User
Default stock shift ****
anyone know how to remove the stock shift ****...i tried spinning it, but it wont seperate from the boot...and the shift boot ends in a rectangular shape. can an aftermarket **** be put on?
Old Aug 15, 2001 | 05:46 AM
4doorH22's Avatar
Default Re: stock shift **** (whiteconfusion)
If I recall correctly, the **** screws off, then you just gotta force it off the boot. It's got like a little plastic retainer clip that keeps it attached to the boot.
Old Aug 15, 2001 | 09:50 AM
tensai's Avatar
New User
Default Re: stock shift **** (H22power)
what about the rectangular shape of the boot? will an aftermarket **** fit?
Old Aug 16, 2001 | 05:16 AM
4doorH22's Avatar
The rectangular top of the boot is due to a plastic insert which you have to remove. The shift lever is just threaded at the top, and most aftermarket ***** should screw on or slip over it and are held in place by a few tiny alan screws. I have yet to find a nice way to make the top of the boot to match up nicely to an aftermarket ****.
Old Aug 17, 2001 | 12:01 PM
tensai's Avatar
New User
thanks for the help H22power, the stock **** came off just like you said and the aftermarket one screwed on nicely...the only problem is the boot... cant get it to stick on the ****...
Old Aug 17, 2001 | 12:06 PM
4doorH22's Avatar
Yeah like I said I can't find a way to make the boot match up neatly to the ****. My boot has just been sitting right below the **** with threads stickin out and everything for years. Some day I'll find a way to stuff the top of the boot under the metal retaining ring under the ****.
Old Aug 17, 2001 | 12:23 PM
tensai's Avatar
New User
haha.....i just push the boot down, exposing a lot of the shifter ...it doesnt look that bad...
Old Aug 17, 2001 | 12:32 PM
4doorH22's Avatar
My shift rod looks nasty. I guess yours is nice and shiny?
Old Aug 17, 2001 | 01:20 PM
tensai's Avatar
New User
not really, but i can manage...looks better than any other setup, IMO
Old Aug 22, 2001 | 11:45 AM
bolognatits's Avatar
New User
I just put a new shift **** on and had the same problem. So what i did was to take out the center console (very easy at least in my 1991 accord) the pull the boot out from the bottom. Then disconnect the band that hold the plastic thing on. Then pull the top edge of the boot in making a little lip. Then get a zip tie and put it inside the lip. Then put the console back in and tighten the zip tie Make sure the spot where it connects to it self is in the back so it doesnt rub on your hand believe me it will be annoying if it does.
Old Aug 22, 2001 | 11:54 AM
4doorH22's Avatar
Default Re: stock shift **** (bolognatits)
Yeah dude I tried the same thing but there was still a little sliver of the shifter shaft showing between the folded-over top of the boot and the bottom of the ****... mine still looks better if i just leave the boot as is so I goes all the way up to the bottom of the ****.
Is your shaft showing at all?
Old Aug 23, 2001 | 10:59 AM
New User
No it is covered up totally. Mabey my **** goes further down the shaft then yours does.
Old Aug 24, 2001 | 08:00 AM
m0t0rhead's Avatar
Buy an aftermarket shift boot... they're cheap and they have REAL nice ones with different color threads and everything.
They even have an S2000 boot you can buy that looks badass.
real leather too.
Old Aug 24, 2001 | 12:11 PM
tensai's Avatar
New User
Default Re: stock shift **** (Escobar)
how much do they usually go for? and where can you buy them? are they special order or something?
K20Z3CivicSiVTEC
Sep 20, 2007 07:05 PM
Shinbo
Oct 8, 2004 01:27 PM
pre1udekid
Jul 12, 2004 03:49 PM
PAID-$$$
May 8, 2003 10:48 AM
andrewasf77
Nov 10, 2002 11:50 AM
