Getting 16 ' chrome rims for my LS Whats the best front strut bar i can get?
New User
Does it really make a difference, any suggestions? dont want to spend more than 110 bucks thats for sure trying to get best bang for your buck any helps thanks!
New User
Any help, what if i put the rims on first without the strut bar for a month will it cause a problem??
Having a strut bar is better because the frame will be more rigid. Putting 16" rims without a strutbar would not cause any problems. I recomend the neuspeed strutbar.
New User
Thanks appreciate it, now how low should i drop it my car is for daily driving as well so i dont want it slammed what springs would u recommend?
Well, first of all, i have a 92 teg so it might be different for your car. I have H&R sport which drops 1.8" all around, i think it's like 1.8" F and 1.5 R for your car. I would recomend that since I have tried it and the ride isn't harsh at all with my tokico blues. You might want to try Eibach sportlines (also 1.8") or the Prokit which drops 1.3" i think. If that's still too high then go with H&R race which lowers about 2-2.5"
Coilovers are good too if you want adjustability and if you have the money.
Also, ask shops around your area and maybe you can see some cars with springs so you can decide easier.
Good Luck.
Good Luck.
I'd also recommend the neuspeed bar, sprint also makes one with the same design. I'd go for springs with no more than about a 1.5" drop, that will get rid of most of the fender gap while not being to low. Eibach pro-kit, Comptech, H&R O.E, Neuspeed sofsport, all won't drop more than 1.5
Honda Sebas
Honda Civic (2001 - 2005)
Jun 28, 2011 09:22 PM
