What should I look out for on older Teg?
Old Aug 24, 2003 | 11:27 AM
NCchris's Avatar
Default What should I look out for on older Teg?
Looking to purchase a 94 GSR. Found one with 122k mi. Looks good, no mods, very clean interior, dealer offers carfax report etc. No obvious damage or rust (southern car). What, if anything should I look out for on an older Teg?
TIA
chris
Old Aug 24, 2003 | 11:29 AM
RedStarGsr's Avatar
check to see if alternator has been replaced, radiator, wires, cap, brakes...basic things that you may have to pick up down the line (which can involve upgrading )
most likely the lca bushings (if you plan on doing shocks or lower tie bar) will be shot and you will have to burn them or have them pressed out. with no rust, id say if everything else is in line, go for it, and good luck.
Old Aug 24, 2003 | 12:28 PM
thaiphob's Avatar
Nikon!!!
Default Re: (RedStarGsr)
you might want to take the car to a mech you trust and do a compression/ leakdown test also.
Old Aug 24, 2003 | 02:19 PM
King_j's Avatar
Default Re: What should I look out for on older Teg? (NCchris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NCchris &raquo;</TD></TR><TR><TD CLASS="quote">Looking to purchase a 94 GSR. Found one with 122k mi. Looks good, no mods, very clean interior, dealer offers carfax report etc. No obvious damage or rust (southern car). What, if anything should I look out for on an older Teg?
TIA
chris</TD></TR></TABLE>
timing belt. if it hasnt been done i suggest doing it. its very easy, like 4 out of 10. the timing can be a bitch though. good luck on the car.
Old Aug 24, 2003 | 02:39 PM
Slain's Avatar
timing belt and water pump
master cyl for transmission
everything else seems to be covered above
good luck
blackhbkid
Jan 28, 2008 08:20 AM
Rowdy
Sep 4, 2007 12:34 AM
thegod
May 17, 2006 04:39 PM
90LudeSiALB
Aug 9, 2005 10:59 AM
vtecsoldseperately
Aug 6, 2003 02:45 PM
