Belt noise when shutting car off
Old Aug 24, 2003 | 07:00 AM
Rick's Avatar
Default Belt noise when shutting car off
Just about everytime I shut my car off, I hear one of the belts make a squeeking noise. Do you reccomend using belt lubricant? Anyone have an idea which belt it could be? Sounds like it is coming from the passenger side, but I'm not sure.
Old Aug 24, 2003 | 07:03 AM
Rory Breaker's Avatar
Default Re: Belt noise when shutting car off (Rick)
Is it an air noise, like a whistle, or a belt squeak?
Check the tension of your belts...theyre all on the drivers side. If any feel lose, tighten them up.
Old Aug 24, 2003 | 07:04 AM
Rick's Avatar
Default Re: Belt noise when shutting car off (newgsrdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsrdriver &raquo;</TD></TR><TR><TD CLASS="quote">Is it an air noise, like a whistle, or a belt squeak?
Check the tension of your belts...theyre all on the drivers side. If any feel lose, tighten them up.</TD></TR></TABLE>
It's a belt squeek. I will go check the tension on them right now.
Old Aug 24, 2003 | 07:24 AM
Rick's Avatar
They are all tight. Only one I didn't check was the timing belt.
Old Aug 24, 2003 | 09:29 AM
mingchi69's Avatar
I to Smooch Pickle
timing belt's don't squeal.. or slip... if it does.. you'll definately know.. so its not yr timing belt.
Old Aug 24, 2003 | 11:47 AM
Rick's Avatar
Default Re: Belt noise when shutting car off (mingchi69)
Anything else I can check that might make a similar noise besides the belts?
Old Aug 24, 2003 | 06:18 PM
mingchi69's Avatar
I to Smooch Pickle
it's the belts.. i've seen it a few times.. where it squeals just right before it shuts off... try tightening it slightly.. or put belt dressing on.
Old Aug 25, 2003 | 05:18 AM
JimBlake's Avatar
Listen under the hood while you have someone turn off the engine. If you've already check the condition & tension of your belts, the best thing now is to narrow down the location of the sound.
Outlaw-Hondaz
Oct 9, 2009 05:31 PM
NikeSB
Sep 14, 2006 04:23 PM
bam181
Aug 20, 2006 05:16 AM
flat-blk-HB
Apr 17, 2005 06:10 AM
cr00klyn718
Sep 5, 2003 12:53 PM
