90 Civic EX Knuckles, do they fit a 89 CRX??
Old Aug 24, 2003 | 12:51 AM
Torino91LS's Avatar
Default 90 Civic EX Knuckles, do they fit a 89 CRX??
I need to know if these fit with no problems. I tried DA and they seemed ok, but i took them off cause the upper a arm was hitting the frame.
Old Aug 24, 2003 | 01:45 AM
bryant's Avatar
Default Re: 90 Civic EX Knuckles, do they fit a 89 CRX?? (kincaidcrxsi)
EX yes
DA should work also. You might need the upper control arm
Old Aug 24, 2003 | 02:33 AM
Torino91LS's Avatar
Default Re: 90 Civic EX Knuckles, do they fit a 89 CRX?? (Bryant)
cool anyone have pics of this setup??
This is my DA setup, that didn't work well. Brake great but had alignment issuses.
Old Aug 24, 2003 | 04:46 AM
NCchris's Avatar
Yes, I am using the EX knuckles on my 90 HF. I "think" the EX geometry is slightly different because before my swap, I had no camber issues with my prokits. After B18 and EX knuckle installation, there was noticable negative camber. I know the extra weight of the B18 will make it sit lower and cause more neg camber but this seemed more than could be attributed to just 1/4 - 1/2 inch lower. I know for sure the Teg knuckles are different. Anyway, the Spec Prod adjustable upper balljoints fixed the prob. FWIW, the EX and teg rotors are the same!
HTH
edit: See StorminMatt's post on the SPC balljoints if you decide to use those.
chris
Old Aug 24, 2003 | 05:30 AM
Jared's Avatar
Default Re: 90 Civic EX Knuckles, do they fit a 89 CRX?? (NCchris)
Are you sure you got EX knuckles? I've seen camber go negative after installing DA knuckes because they're taller, but the EX swaps I've seen change nothing.
Old Aug 24, 2003 | 09:51 AM
mattb16a1civic's Avatar
if its a 90 ex it should be fine. we have a 92 jdm sir knuckle on our 90 si crx, we have alot of positive camber but we havent adjusted the coilovers yet hopefuly that will be enough to straighten it out
Old Aug 24, 2003 | 02:48 PM
bryant's Avatar
Default Re: 90 Civic EX Knuckles, do they fit a 89 CRX?? (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure you got EX knuckles? I've seen camber go negative after installing DA knuckes because they're taller, but the EX swaps I've seen change nothing.</TD></TR></TABLE>
This would be right. DA knuckles you will have more negative camber. EX knuckles nothing will change.
Old Aug 24, 2003 | 02:58 PM
NCchris's Avatar
Yeah, took them off myself.
chris
Old Aug 24, 2003 | 05:27 PM
philly-O's Avatar
a buddy of mine had the teg knuckles and had to notch the upper control arm to give clearance for travel. i just picked up a set of 90 ex knuckles for my car last week for $150.
Old Aug 24, 2003 | 10:44 PM
Torino91LS's Avatar
Default Re: 90 Civic EX Knuckles, do they fit a 89 CRX?? (peichie)
Thanks for the replies, I'm picking the up tommorrow.
safehandle
May 5, 2019 07:09 PM
fastcrxsi90
12
Nov 6, 2002 08:38 PM
rice4life
15
Aug 12, 2002 10:39 PM
Speed PHreak
Aug 8, 2002 07:05 PM
Dano
Jun 14, 2002 10:45 AM
