Y1 LSD same as S1 trannies?
Old Aug 23, 2003 | 07:40 PM
spooned out's Avatar
Default Y1 LSD same as S1 trannies?
okay i have a cable b16a 1st gen with the S1 tranny and need to knoe if i can swap it with the Y1 tranny with LSD... Whats the difference between the S1 and the Y1 LSD tranny? i'm looking to replace my s1 tranny because the synchros have gone bad, since a used tranny will cost less i figure just get a used one maybe the Y1 LSD but need to knoe if it would be a direct swap.
Old Aug 23, 2003 | 07:54 PM
fourthgenhatchB17's Avatar
Default Re: Y1 LSD same as S1 trannies? (spooned out)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooned out &raquo;</TD></TR><TR><TD CLASS="quote">okay i have a cable b16a 1st gen with the S1 tranny and need to knoe if i can swap it with the Y1 tranny with LSD... Whats the difference between the S1 and the Y1 LSD tranny? i'm looking to replace my s1 tranny because the synchros have gone bad, since a used tranny will cost less i figure just get a used one maybe the Y1 LSD but need to knoe if it would be a direct swap. </TD></TR></TABLE>
Yes it will be a direct swap. Diff. between the two trannys is Y1 has LSD and the Y1 has diff. gear ratios too. I hear the Y1 trannys have slightly taller gear ratios than the S1.
Old Aug 23, 2003 | 09:48 PM
then its perfect, im boosting soon so taller gear ratios will work for me.... thanks
Old Aug 24, 2003 | 10:13 AM
Default Re: (spooned out)
Where did u get the Y1 LSD tranny from and how much?
Old Aug 24, 2003 | 12:50 PM
davens's Avatar
Good luck...the y1, especially with LSD, is pretty rare. And if the seller knows what they have, expect to pay a pretty penny.
Old Aug 24, 2003 | 01:27 PM
Default Re: (davens)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davens &raquo;</TD></TR><TR><TD CLASS="quote">Good luck...the y1, especially with LSD, is pretty rare. And if the seller knows what they have, expect to pay a pretty penny.</TD></TR></TABLE>
No **** thats why im askin him how much he got his for. The Y1 itself with no LSD isnt that rare I've seen a few here and there, but the LSD one can be.
Old Aug 24, 2003 | 03:50 PM
johnzm's Avatar
i have a Y1/lsd coming out of my car, a YS1/LSD and 4.78 FD going in. nothing is rare if you know where to look.
Old Aug 24, 2003 | 04:09 PM
Full-Race Henry's Avatar
Default Re: (johnzm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnzm &raquo;</TD></TR><TR><TD CLASS="quote">i have a Y1/lsd coming out of my car, a YS1/LSD and 4.78 FD going in. nothing is rare if you know where to look.</TD></TR></TABLE>
what 4.78 FD is going in?? where did you get it? how much was it?
Old Aug 24, 2003 | 04:16 PM
johnzm's Avatar
Default Re: (EF8_Fan)
the final drive can be found in many places. i dunno if its going to fit yet, i have been told that it will from people on HT- itll be a first for local kid.. also my lsd, ATS lsd, i am still trying to find a speedo gear for it that is compatible with the cable trans. they make one its 75 dollars but i dont think its going to work with a cable sensor..
Old Aug 24, 2003 | 07:42 PM
davens's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">No **** thats why im askin him how much he got his for. The Y1 itself with no LSD isnt that rare I've seen a few here and there, but the LSD one can be.</TD></TR></TABLE>
Yes ****. That was a response for spooned out, the original poster. If I was talking to you, I would've put a nice set of quotes around your post.
I still think it would be prudent to set his expectations...a y1 lsd is a rare and expensive tranny when compared to the several other B-series trannys.
Old Aug 24, 2003 | 08:50 PM
I haven't had time to call the place yet but advertised that they had the Y1 LSD, all i'm looking to do is replace my bad S1 tranny (synchros) to one with LSD, my friend has the S1 with LSD (optional?) .. well ill post prices up as soon as i can for those that are curious
spooned out
Aug 26, 2003 06:56 AM
spooned out
Aug 24, 2003 10:15 PM
thaiphob
Sep 22, 2002 05:52 AM
