need help on removing window tint
Old Aug 23, 2003 | 06:11 PM
sho's Avatar
sho
Default need help on removing window tint
I need to know whats the best way to remove window tint, cause the tint on my moms car is starting to come off. Any help would be appreciated. TIA
Also I wasnt sure if this was the right area to post this so Moderators feel free to move to where ever this type of topic should be.
Old Aug 23, 2003 | 06:50 PM
HiRevn's Avatar
Default Re: need help on removing window tint (sho)
Spray the windows down with a water/ammonia mix. Let it sit for a little bit then scrape it off with a blade. The ammonia breaks down the adhesive of the tint.
That's why they never recommend using windex on tinted windows.
Old Aug 23, 2003 | 06:51 PM
Steve90HB's Avatar
This should probably be in the tech, but from my experience a razor would be the best way to do it... I think the tint places will take off your old tint for no charge if you get some more
Old Aug 23, 2003 | 07:10 PM
Coogster's Avatar
There is a product available too remove the adhesive from the film, check the local auto parts store, or as i did, used a razor and white vinegar, cheap.
Old Aug 23, 2003 | 09:16 PM
Stripped Honda's Avatar
99-0104
Default Re: need help on removing window tint (Coogster)
i personally use brake clean on the glass it dizzolves the glue very nicely
Old Aug 23, 2003 | 09:23 PM
VTECorona's Avatar
Default Re: need help on removing window tint (Stripped Honda)
Do not scrape the rear window! Spray windex on it repeatedly and use a scrotchbrite pad on it or something. There is also a product called tint-off, get that if you have the means.
Old Aug 23, 2003 | 09:29 PM
Team's Avatar
Default Re: need help on removing window tint (VTECorona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECorona &raquo;</TD></TR><TR><TD CLASS="quote">Do not scrape the rear window! Spray windex on it repeatedly and use a scrotchbrite pad on it or something. There is also a product called tint-off, get that if you have the means.</TD></TR></TABLE>
and this method wont scratch your window glass?
Old Aug 23, 2003 | 09:54 PM
VTECorona's Avatar
Default Re: need help on removing window tint (Team)
a scotchbrite pad? not even close
EK k kay
Aug 23, 2005 03:36 PM
KAYTHAN
Sep 11, 2004 08:30 AM
JdmLsPwr425
Mar 10, 2004 07:34 PM
youngwon22
Aug 24, 2003 07:32 AM
IdotheSHOCKER
Jun 1, 2002 05:00 AM
