Si Tranny
Old Aug 23, 2003 | 05:47 PM
Civic138's Avatar
Default Si Tranny
will a 88-91 si tranny bolt directly to a dx motor? i've searched and couldn't find anything,sorry if already asked.
Old Aug 23, 2003 | 06:10 PM
tdaccord's Avatar
Default Re: Si Tranny (Civic138)
yes it will
Old Aug 23, 2003 | 08:40 PM
Louie B.'s Avatar
what year DX engine? will you be using the old flywheel?
basically:
88 flywheel / clutch will only work with an 88 tranny
89 flywheel / clutch will work with 89-91 tranny
90-91 flywheel / clutch (Ideal) will work with 89-91 tranny
Old Aug 23, 2003 | 09:16 PM
Civic138's Avatar
Default Re: Si Tranny (thumpu77)
yea it's a 90 hatch i'm tired of the 4-speed i need a 5-speed bad no i'm going to get an aluminum flywheel in place of the stock one
Old Aug 23, 2003 | 09:40 PM
Louie B.'s Avatar
then definately get the 90-91 flywheel, 90-91 clutch kit, and 89-91 Si tranny. You can ID this tranny by the stamp on it that says:
PL3
3000
are you getting the tranny for freeway cruzing or performance?
5th gear in an Si tranny is the same as 4th gear in a 4-speed.
Old Aug 23, 2003 | 10:07 PM
Civic138's Avatar
i'm basiclly getting it for both, i'm completely rebulding the motor and getting everything my hard earned money i can get for internal mods (my main concern) with some boltons. some of the kids in franklin will pay anything for a car as long as it's an honda.... 's to me on that one,i just want to get as much hp i can out of the dx motor
Old Aug 24, 2003 | 06:36 AM
Louie B.'s Avatar
good strategy... you can always add the bolt-ons later
the head work is where you'll get the most gains internally, focus there. The Si cam and valve springs will fit, as well as aftermarket versions made for the Si. I wouldn't do the cam without the valvesprings though.
do you have the mpfi swap yet?
just my $.02
Old Aug 25, 2003 | 03:01 PM
Civic138's Avatar
i'm going to start on it once i get the tranny so itll get done in 2 days at the most
honcrx91si
Aug 14, 2005 08:56 PM
lovinthecrx
May 13, 2005 08:11 PM
T-Mo
Jan 1, 2004 07:57 PM
yaoming
Mar 23, 2003 06:34 PM
