Need to Talk to the guy who sells the S2K antenna conversion kit.
Old Aug 23, 2003 | 05:10 PM
AcuraLaw's Avatar
Default Need to Talk to the guy who sells the S2K antenna conversion kit.
Looking for the guy, or supplier that sells the s2K antenna conversion kit for the DC-4 GS/LS Teg. Need to purchase one.
Old Aug 23, 2003 | 06:08 PM
96 Ls lnTeG's Avatar
Default Re: Need to Talk to the guy who sells the S2K antenna conversion kit. (AcuraLaw)
I Got mine From here http://locustom.com/frameset/home.htm
Heres a pic of mine...
an if you nee to see pics.. of the install check this out they used a different kit though http://www.team-integra.net/se...D=815
Old Aug 23, 2003 | 06:25 PM
beaterman's Avatar
Default Re: Need to Talk to the guy who sells the S2K antenna conversion kit. (sil2civic)
how was the install on the s2k antenna. was it hard to do. and also did you just follow the instructions from team-integra.net
Old Aug 23, 2003 | 06:38 PM
AcuraLaw's Avatar
Default Re: Need to Talk to the guy who sells the S2K antenna conversion kit. (beaterman)
The shark attack II is a nice model. I'm going ahead and going with that one, easy install, no crazy **** happening, thanks for the recommendation.
Old Aug 23, 2003 | 06:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaterman &raquo;</TD></TR><TR><TD CLASS="quote">how was the install on the s2k antenna. was it hard to do. and also did you just follow the instructions from team-integra.net</TD></TR></TABLE>
Well the install was easy... the only thing i had to do was lengthin the ground wire... i grounded it to the top bolt of that holds the tail light
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AcuraLaw &raquo;</TD></TR><TR><TD CLASS="quote">The shark attack II is a nice model. I'm going ahead and going with that one, easy install, no crazy **** happening, thanks for the recommendation.
I did not use the Shark Attack II I Used the S2000 Kit... I did not have to mod the s2000 Kit 2much besides lengthin the ground wire an shortin the post a little which was to long other than that it came out good sounds good as stock if not better
Old Aug 24, 2003 | 05:46 AM
SoCar's Avatar
my s2k antenna install was fairly easy, good luck with the shark attack acura law
Old Aug 24, 2003 | 11:33 PM
BlueIntegraBoy's Avatar
I did a shark attack on my teg. Fairly simple, just take out old antenna and screw in this one. There are two wires, power and the antenna/signal. Here's a pic.
I know the base looks slanted, but this is the way I want it. The mast is actually parallel with the body.
import810
Sep 24, 2025 10:35 PM
MAD ITR 55
May 21, 2006 09:50 PM
01ITR#700
Aug 7, 2003 06:46 AM
kepani
Jun 10, 2002 05:17 PM
DC2-R
Apr 28, 2002 06:30 PM
