white smoke???
Old Aug 23, 2003 | 05:02 PM
xavierfg's Avatar
Default white smoke???
i just completed the MPFI swap on a 91 CRX DX w/ automatic transmission. At first, i was leaking coolant from the gasket connecting the block to the intake manifold. I fixed that, but only after leaking a LOT of coolant out the bottom of the engine bay and maybe into the engine?
There is also a lot of white smoke coming out of the exhaust pipe and was just wondering if anyone knew where it was from, maybe from the coolant burning?
Here are the parts i used:
- 91 si intake manifold, throttle body, fuel rail/injectors, etc.
- 90 si distributor
- 88-89 integra LS automatic transmission ECU
- 91 si injector resistor box
Any help is appreciated, thanks.
Old Aug 23, 2003 | 08:34 PM
Louie B.'s Avatar
Default Re: white smoke??? (xavierfg)
I think I pretty much answered it on your other post...
https://honda-tech.com/zerothread?id=599734
basically there will be coolant in your exhaust for the next week or so. so there shouldn't be anything to worry about
Old Aug 23, 2003 | 08:58 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
Hopefully you didn't warp your head, or your block... that'll do it, as well as a faulty headgasket.
MitchHamilton
May 27, 2016 05:15 AM
724chris
13
Oct 13, 2010 03:28 AM
Prudz_lude
Apr 22, 2007 08:42 PM
JDMfrontedLS
Apr 14, 2006 04:43 PM
