FS:91 Civic DX $500 (Chicago)
Im selling it for a friend, its a frost white 91 civic DX hb, the shell has around 150,000 miles on it, motor about 110,000, it has been wired from duel point injection to multipoint, the motor was replaced with a 88 crx HF motor, it has an SI ecu, SI Cluster, SI lip, SI Distributor, SI Tranny. short shifter, ACT disk, Skunk2 coilovers, Tokico Illuminas, $250 alarm, clear corners, OEM clear bumper lenses, flat black hood, 13" rimes w/ tires, B16 throttle body, 93 DX Intake Manifold(larger ports). The fram is good, never been in a major accident, only one minor(fender and front bumper were slightly damaged). the only problem w/ the car is that it doesnt run, the car startes but it doesnt drive, the clucth isnt properly aligned. also it seems that the intake manifold gasket is screwed, so it smokes crazy, and idles at 2500, no vacuum leaks, me and my friends are tired of tring to fix it. he want $500, its in the north side of chicago, no lowballers, or flakes, thanks
Need to sell ASAP!!!!!!!!!!!!!! Local or Pick up only!!!!!!!!!!!
ineedacrx
Nov 14, 2005 04:38 PM
simike
Aug 13, 2002 02:50 PM
