Mixing paints = BAD, VERY BAD!
So....I finished the body work on the door that needed repairing after the last NorCal WCHC race. Derek had to do avoidence manuevers off track & there was some body damage. While the body work wasn't pristine, it turned out fairly good for a ghetto race car. I found a brand of paint that semi-matches the other paint. I put on three coats of spray paint. I wet sanded. I also wanted to put on a top coat of clear. Here is where it gets bad...for me at least. I had to buy a different brand of clear. They are not, repeat not compatible. I now have orange peel in various areas of the repaired area.
@ this point, I guess I need to wait for it to dry & then sand the hell out of it & start again.
Ain't low budget racing grand!
added in edit: Screw it. I sanded....a little. I painted. Just don't look @ it when you are closer than 5' away.
Modified by civicrr at 9:26 PM 8/23/2003
it might not have been compatibility - i had the same experience when spray painting & clearcoating, and it was because the paint wasn't completely dry. in certain spots, almost as soon as the clear coat hit it 'peeled', others took a few seconds longer.
did you use the 'oem color match' stuff from dupli-color, or just a close match? i think they make all the si colors.
View your results.
Manufacturers Color Code: B95P
Dupli-Color¨ Color Code: 00980
Color Name: Electron Blue Pearl
edit: oops, you don't drive an si. sorry - got you confused with some other internet person i don't know.
anyhow, the dupli-color website may have some helpful info for you. good luck.
The shell was painted yellow when I bought it. The (color) paint had two days of 90*+ heat to dry. I have used the dupli-color paints on other projects with good results. Unfortunately, I didn't see anything close to a match in their in store book.
phantom_sol
Nov 7, 2003 07:52 AM
