Compression test ?
Old Aug 23, 2003 | 11:48 AM
RCautoworks's Avatar
Default Compression test ?
When I did my compression test, I don't think my engine was at wide open throttle. All my numbers were really good though. So should I even worry about it ? Does it make that much of a difference ?
Old Aug 23, 2003 | 12:09 PM
Default Re: Compression test ? (90blackcrx)
By the way my numbers were
#1 230/235
#2 225/230
#3 225
#4 235
So should I redo it since my throttle was about 98% open ?
Old Aug 23, 2003 | 12:37 PM
SICKSOLSI's Avatar
those are good numbers
Old Aug 23, 2003 | 12:40 PM
Default Re: Compression test ? (95excoupeMT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95excoupeMT &raquo;</TD></TR><TR><TD CLASS="quote">those are good numbers </TD></TR></TABLE>
So you don't think I should worry about doing it over ?
Old Aug 23, 2003 | 01:45 PM
SICKSOLSI's Avatar
i wouldnt be too concerned those are the same numbers my 00 gsr motor puts out...is that an si crx?
Old Aug 23, 2003 | 04:47 PM
asmallsol's Avatar
98% is basicly WOT. Your numbers are fine. Next time, try without any throttle. The number would be at like 100 or so. You just basicly have to have the throttle floored.
Old Aug 23, 2003 | 05:27 PM
SICKSOLSI's Avatar
Default Re: Compression test ? (asmallsol)
the important thing is that your numbers should be within 10psi as a rule of thumb so youre good
EG2Driver
Jul 12, 2006 04:01 PM
98prelude98
Apr 12, 2005 08:39 AM
92siracer
Jun 2, 2004 10:29 PM
dirtySOHC's
27
Jun 11, 2002 05:38 PM
jaredfmn
May 30, 2002 11:33 AM
