Hondata/wideband
You have to wire the wideband to the stock O2 pins, and then calibrate the sensor voltage chart, under settings then lambda. Just need the voltage to A/F chart from the manufacturer of your wideband.
Wiring
1- wire for 12v for heater (A6)
1- Heater ground
1- siganl ground
1- O2 signal (d14)
I am 99% sure those are the GSR pin points.
Wiring
1- Heater ground
1- siganl ground
1- O2 signal (d14)
